I Can't remove Signal-Desktop (https://signal.org/) in Ubuntu 20.x
The app was originally installed by using Signal official website installation instructions:
Linux (Debian-based) Install Instructions
NOTE: These instructions only work for 64 bit Debian-based Linux distributions such as Ubuntu, Mint etc.
Install our official public software signing key
wget -O- https://updates.signal.org/desktop/apt/keys.asc | gpg --dearmor > signal-desktop-keyring.gpg cat signal-desktop-keyring.gpg | sudo tee -a /usr/share/keyrings/signal-desktop-keyring.gpg > /dev/nullAdd our repository to your list of repositories
echo 'deb [arch=amd64 signed-by=/usr/share/keyrings/signal-desktop-keyring.gpg] https://updates.signal.org/desktop/apt xenial main' |\ sudo tee -a /etc/apt/sources.list.d/signal-xenial.listUpdate your package database and install signal
sudo apt update && sudo apt install signal-desktop
ISSUE
To remove the signal-desktop I use any of the following:
$ sudo apt-get purge signal-desktop
$ sudo apt remove signal-desktop
Every time the removal is attempted it gives the following message:
E: Malformed line 3 in source list /etc/apt/sources.list.d/signal-xenial.list (type)
E: The list of sources could not be read.
Using sudoedit /etc/apt/sources.list.d/signal-xenial.list
I can open the file that shows
deb [arch=amd64 signed-by=/usr/share/keyrings/signal-desktop-keyring.gpg] https://updates.signal.org/desktop/apt>
$ sudo apt-get update also doesn't work as I get the message
I am not sure how to remove Signal.
