I moved all my data to a new drive and it seems to be lost. Please help me to recover the data.
Here is what I did to make the problem occur:
I moved, not copied the data. (First mistake)
The HDD was making noises when I moved the data. Since the drive is new and the SMART values all looked good, I didn't worry too much about it, but maybe I should have?
To use the data I plugged in the drive into a Windows machine. (Second mistake) I tried to use DiskInternals LinuxReader to be able to read the ext4 format. Some files were readable other folders threw an error or appeared empty.
I plugged in the drive into the original Ubuntu machine, only to see the same results.
What I tried to fix it:
The first recommendation was to make a
ddbackup of the entire disk. I did that.
Although when checking afterwards withdf -hthe original disk showed 981G used and the copy only showed 80K in use. So maybe something there went wrong?This morning I tried to continue after a reboot and suddenly I couldn't mount either disk:
special device /dev/sdb1/ does not exist (a path prefix is not a directory).
I tried what was suggest here and runsudo blockdev --rereadpton both disks, but it ran without any feedback and the mount was still not possible. Since I planned on using e2fsck, I didn't worry about that too much, since I had to use an unmounted disk anyway.I ran
gdiskwithrto get to recovery options and then withbandcto read and recover the partition table from the secondary table. Sincevgave no errors, I confirmed the write withw.Since that didn't work, I finally tried
e2fsck. I confirmed everything it asked me to. Mostly invalid checksums, empty or "garbage" inodes and wrong counts for groups. Everything I read said this process might take hours, but it only ran ten minutes.
After that the mount finally worked, but df -h shows only 6.9G (There should be 981G) in use. The drive appears to be empty apart from around 50 entries in lost+found, so not nearly enough to cover all the files lost.
I don't know how to proceed and can't seem to find more answers on my own.
Why weren't the drives mountable anymore? - Answered by @mchid, thanks!
What can I try next, to have a chance at recovery of the data?
And if someone has the patience to educate me:
Did plugging the ext4 drive into a windows machine corrupt it? If so, why? From what I understood with the correct drivers (i.e. LinuxReader) it should be readable.
Any reply is greatly appreciated. Thanks for any help in advance!
Edit to add:
lsblk output:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 8G 0 disk
├─sda1 8:1 0 1M 0 part
└─sda2 8:2 0 8G 0 part /
sdb 8:16 0 3.7T 0 disk
└─sdb1 8:17 0 3.7T 0 part
sdc 8:32 0 3.7T 0 disk
└─sdc1 8:33 0 3.7T 0 part
sdd 8:48 0 1000G 0 disk
└─sdd1 8:49 0 1000G 0 part /data
parted output:
(parted) print
Model: QEMU QEMU HARDDISK (scsi)
Disk /dev/sdb: 4001GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 4001GB 4001GB ext2
