I am running Ubuntu 20.04 on my laptop. Ever since the installation I have never had any problems with the date/time going out of sync.
But today when I started the laptop the system time was completely wrong. I can disable NTP and set the correct time manually but the moment I re-enable NTP the time jumps back to being wrong:
david@david-XPS-15-9570  ~  timedatectl
               Local time: Mo 2021-10-04 08:20:36 CEST
           Universal time: Mo 2021-10-04 06:20:36 UTC
                 RTC time: Mo 2021-10-04 06:20:37
                Time zone: Europe/Vienna (CEST, +0200)
System clock synchronized: no
              NTP service: inactive
          RTC in local TZ: no
 david@david-XPS-15-9570  ~  sudo timedatectl set-ntp on
               Local time: Mo 2038-10-04 07:52:04 CEST
           Universal time: Mo 2038-10-04 05:52:04 UTC
                 RTC time: Mo 2021-10-04 06:21:14
              NTP service: active
          RTC in local TZ: no
  • I have rebooted the laptop multiple times, just to be sure
  • I checked the date and time in the BIOS - they are correct
Any idea what's going on here?
ADDITIONAL INFO:
AFAICT, NTP should be querying ntp.ubuntu.com
david@david-XPS-15-9570  ~  cat /etc/systemd/timesyncd.conf
#  This file is part of systemd.
#  systemd is free software; you can redistribute it and/or modify it
#  under the terms of the GNU Lesser General Public License as published by
#  the Free Software Foundation; either version 2.1 of the License, or
#  (at your option) any later version.
# Entries in this file show the compile time defaults.
# You can change settings by editing this file.
# Defaults can be restored by simply deleting this file.
# See timesyncd.conf(5) for details.
[Time] #NTP= #FallbackNTP=ntp.ubuntu.com #RootDistanceMaxSec=5 #PollIntervalMinSec=32 #PollIntervalMaxSec=2048
... which, according to https://servertest.online/ntp should be fine...
MORE ADDITIONAL INFO:
david@david-XPS-15-9570  ~  service chronyd status
Unit chronyd.service could not be found.
david@david-XPS-15-9570  ~  service systemd-timedated status
● systemd-timedated.service - Time & Date Service
     Loaded: loaded (/lib/systemd/system/systemd-timedated.service; static; vendor preset: enabled)
     Active: active (running) since Mon 2021-10-04 14:47:02 CEST; 14s ago
       Docs: man:systemd-timedated.service(8)
             man:localtime(5)
             https://www.freedesktop.org/wiki/Software/systemd/timedated
   Main PID: 9393 (systemd-timedat)
      Tasks: 1 (limit: 38042)
     Memory: 1.3M
     CGroup: /system.slice/systemd-timedated.service
             └─9393 /lib/systemd/systemd-timedated
Okt 04 14:47:02 david-XPS-15-9570 systemd[1]: Starting Time & Date Service... Okt 04 14:47:02 david-XPS-15-9570 systemd[1]: Started Time & Date Service. david@david-XPS-15-9570  ~  sudo timedatectl set-ntp on
david@david-XPS-15-9570  ~  service systemd-timedated status ● systemd-timedated.service - Time & Date Service Loaded: loaded (/lib/systemd/system/systemd-timedated.service; static; vendor preset: enabled) Active: active (running) since Mon 2021-10-04 14:47:02 CEST; 16 years 11 months ago Docs: man:systemd-timedated.service(8) man:localtime(5) https://www.freedesktop.org/wiki/Software/systemd/timedated Main PID: 9393 (systemd-timedat) Tasks: 1 (limit: 38042) Memory: 1.4M CGroup: /system.slice/systemd-timedated.service └─9393 /lib/systemd/systemd-timedated
Okt 04 14:47:02 david-XPS-15-9570 systemd[1]: Starting Time & Date Service... Okt 04 14:47:02 david-XPS-15-9570 systemd[1]: Started Time & Date Service. Okt 04 14:47:25 david-XPS-15-9570 systemd-timedated[9393]: systemd-timesyncd.service: Enabling unit. Okt 04 14:47:25 david-XPS-15-9570 systemd-timedated[9393]: Set NTP to enabled (systemd-timesyncd.service). Okt 04 07:52:02 david-XPS-15-9570 systemd-timedated[9393]: Set NTP to enabled (systemd-timesyncd.service). david@david-XPS-15-9570  ~  timedatectl
Local time: Mo 2038-10-04 07:52:18 CEST Universal time: Mo 2038-10-04 05:52:18 UTC RTC time: Mo 2021-10-04 12:47:42
Time zone: Europe/Vienna (CEST, +0200) System clock synchronized: no
NTP service: active
RTC in local TZ: no
I changed the line in the config file to these values
NTP=pool.ntp.org
NTP=pool.ntp.org
NTP=ntp.ubuntu.com
but none made any difference...
