So, I have a 240GB (external)SSD, onto which I'd like to install Ubuntu. Now, after reading a few posts on doing exactly this, I see that one of the common issues people face while doing this is that GRUB gets installed on the internal drive rather than the external one. This makes the the external SSD unbootable on other computers. On top of that, it seems that the internal drive becomes unbootable as well and requires a GRUB reinstall/reconfiguration. So, I was wondering if it were possible to install Ubuntu onto the external drive in the following way:
  1. Create a new VirtualBox VM with no virtual hard disk
  2. Give the VM access to USB ports
  3. Start the VM using an Ubuntu .iso file
  4. Plug in the target external SSD
  5. Install Ubuntu onto the external SSD
Would this work? I really don't want to remove my internal SSD for the installation process. (I've got a MacBook and its quite a pain)
n0pe
  • 121
Well I don't think that this question is too much of nonsens, I am currently trying the same solution. I tried to make bootsticks with the new versions of Ubuntu several times, as I was also interested in trying ROS and using Virtual box which needed new kernel. No flasher worked, neither rufus balenaEchter, the one on an older Ubuntu version, also the modification of the safe loader by specifying the boot destination was unsucessfull. But as I used VirualBox on my Windows machine with limited HDD, Ubuntu was loading and installing fine, but the stick never booted correctly to the install menu. For bad luck there is also no Ubuntu.exe installer so it is also impossible to install the system from the Windows System. Today I wanted to try to create an boot DVD bought the rolins but faced the lack of a DVD burner, thought I would still have one but that was on my even older laptop....
