My root drive (32GB) has run out of space, on ubuntu server 18.04lts. I only run docker and nothing else, and the docker data directory is on a different drive. I tried all the usual tricks to try and free data and i'm still sitting on 100%. I'm wondering if it's too many kernals, but I don't really fully understand about deleting unused ones. I have tried
$ sudo purge-old-kernels
0 upgraded, 0 newly installed, 0 to remove and 110 not upgraded.
$ sudo apt-get --purge autoremove
If I list all the kernals I get the following output: https://pastebin.com/9Xb3BU29
Do you think the kernals are taking up all the space?
Here is the output for sudo df -h: https://pastebin.com/0Ai8UG2c
(note /dev/sdi3 is the root drive that ubuntu runs on)
mike@server:/$ sudo du / -h -x --max-depth=1 2> /dev/null | sort -hr
31G /
27G /var
2.4G /usr
sudo du /var/lib/docker -h -x --max-depth=1 2> /dev/null | sort -hr
26G /var/lib/docker
23G /var/lib/docker/overlay2
1.9G /var/lib/docker/containers
1.2G /var/lib/docker/volumes
