Based on Ubuntu 18.04,
I want to allow users to access only from 9 a.m. to 5 p.m.(working time) on the SSH server. (used OpenSSH-server package)
I've looked up all the materials I think will help you from user management to PAM settings on Google, but I don't think there's any information to restrict access by SSH time zone.
(But, I have not to use firewall-related services like ufw.)
If you can help me, please let me know. Thank you.
(Please understand that my English can be unnatural because I am not good at English.)
The pam_time module is designed for this.
  1. Add pam_time as the first account statement in the ssh pam config. This command will insert the statement account required pam_time.so just above the line @include common-account.
sed -i -e '/^.include common-account/i account required pam_time.so' /etc/pam.d/sshd
  1. configure /etc/security/time.conf as desired. This command will add the configuration sshd;*;*;Wk0900-1700. This limits ssh connections for all users to weekdays between 9am and 5pm.
echo 'sshd;*;*;Wk0900-1700' >> /etc/security/time.conf
See Also
Use a cron job to stop and start the ssh server at specific times. For example create a file /etc/cron.d/start-stop-ssh with the following contents:
0 9 * * * root /usr/sbin/service ssh start
0 17 * * * root /usr/sbin/service ssh stop
This will start the ssh service everyday at 9:00 and stop it everyday at 17:00.
Please note that when the service is stopped nobody (even admin) will be able to login via ssh.
raj
  • 11,409
