Hi i'd like to install windows 11 on kvm.
I have tpm enabled on my system. ubuntu 21.04 (qemu 5.2+dfsg-9ubuntu3.1)
ls -ls /dev/tpm*
0 crw-rw-rw- 1 root root  10,   224 Sep 25 18:18 /dev/tpm0
0 crw-rw-rw- 1 tss  tss  253, 65536 Sep 25 18:18 /dev/tpmrm0
the w11 xml file contains the passthrough code:
<tpm model="tpm-tis">
  <backend type="passthrough">
    <device path="/dev/tpm0"/>
  </backend>
</tpm>
When starting the vm I get the following error:
Unable to complete install: 'internal error: qemu unexpectedly closed the monitor: 2021-09-26T06:28:55.041197Z qemu-system-x86_64: -tpmdev passthrough,id=tpm-tpm0,path=/dev/fdset/3,cancel-path=/dev/fdset/4: '/dev/fdset/3' is not a TPM device.'
Traceback (most recent call last): File "/usr/share/virt-manager/virtManager/asyncjob.py", line 65, in cb_wrapper callback(asyncjob, args, *kwargs) File "/usr/share/virt-manager/virtManager/createvm.py", line 2001, in _do_async_install installer.start_install(guest, meter=meter) File "/usr/share/virt-manager/virtinst/install/installer.py", line 701, in start_install domain = self._create_guest( File "/usr/share/virt-manager/virtinst/install/installer.py", line 649, in _create_guest domain = self.conn.createXML(install_xml or final_xml, 0) File "/usr/lib/python3.9/site-packages/libvirt.py", line 4376, in createXML raise libvirtError('virDomainCreateXML() failed') libvirt.libvirtError: internal error: qemu unexpectedly closed the monitor: 2021-09-26T06:28:55.041197Z qemu-system-x86_64: -tpmdev passthrough,id=tpm-tpm0,path=/dev/fdset/3,cancel-path=/dev/fdset/4: '/dev/fdset/3' is not a TPM device.
Any ideas how to properly pass the tpm to the vm.
Thanks
user63726
  • 764
I have run into the same error.
I refered the next web page and found the Apparmor makes this problem.
I added /dev/tpm0 rw, in /etc/apparmor.d/abstractions/libvirt-qemu right before /dev/net/tun rw, (Notice the ,) and restarted apparmor. The error dialog will not show.
I hope this make some help.
