I want the mouse cursor to hide when I press the HUD key Alt. It should toggle back on if I press Alt again or press Enter.
Problem:
When you press Alt showing the HUD, pressing Enter should execute the first result. However, it will instead select whatever random thing the mouse happens to be over. Example: You press the Alt key then type "mu" then enter. This would normally mute the audio, unless your mouse happens to be over one of the other results in the HUD.
Is there a workaround or solution for this?
edit: This problem is for Unity 2D.
Jorge Castro
  • 73,717
Isaac
  • 693
