I can filter by lots of protocols in wireshark and tshark, like this:
sudo tshark -i <My_Interface> -Y '(ip.addr == <My_IP> and isakmp)'
How can I add the protocol filter in a tcpdump command like this?
sudo tcpdump -i any -nn host <My_IP>
Maf
  • 134
You would use filters on the end. These are called Berklee Packet Filters or BPFs for short. In your example, you could do it this way:
tcpdump -nn -vvv -e -s 0 -X -c 100 -i eth0 host 1.2.3.4 and \(proto 17 and port 500\)
This would capture traffic to or from 1.2.3.4 with Layer-3 protocol 17 (UDP) and Layer-4 port 500. You can also use friendly names if they are present in /etc/protocols and /etc/services like this:
host 1.2.3.4 and \(proto udp and port isakmp\)
There are quite a lot more BPFs you can use to limit things like protocol versions to only capture IPv6 (ip6) or capture traffic that has the SYN flag set in a TCP packet (tcp[tcpflags] == tcp-syn).
If you need a live tool, I've created https://tcpdump101.com which will let you build your tcpdump syntax and BPF so you can just copy and paste it. Hopefully it will help you out.
I could create my own filter after some workarounds:
whileIFS= read -r line; do if [[ $line =~ 'isakmp' ]]; then echo $line; fi; done < <(sudo tcpdump -i any -nn host <My_IP>)
Maf
  • 134
