It's been my first time posting a question. I have install Ubuntu 20.04.3 LTS on a server in order to be my NTP server for my network. I try to install the NTP server but I get the error:
$ sudo apt-get install ntp
Reading package lists... Done
Building dependency tree
 ntp : Depends: libopts25 (>= 1:5.18.16) but it is not installable
       Recommends: sntp but it is not going to be installed
I tried also to install sntp, just in case, but same problem:
$ sudo apt-get install sntp
 sntp : Depends: libopts25 (>= 1:5.18.16) but it is not installable
I also tried the command below to install the libopts25 with NTP but same problem once again.
$ sudo apt-get install ntp libopts25
Package libopts25 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'libopts25' has no installation candidate
It seems that the libopts25 package is missing or obsolete (?). If this package is dependancy for NTP, is there another procedure to install NTP on Ubuntu server?
The server has full access to the internet. Any recommendations will be helpful.
Artur Meinild
  • 31,035
You need to have the universe repository enabled to install ntp and libopts25. Make sure this line is in your /etc/apt/sources.list:
deb http://archive.ubuntu.com/ubuntu focal universe
Then you should be able to install with:
$ sudo apt update && sudo apt install ntp
Artur Meinild
  • 31,035
