I've been trying to install .deb chrome file (google-chrome-stable_current_amd.64.deb) but unable to do. I only get the message saying that "It is not installable" and "Some packages could not be installed".
logs:
sudo apt install ./google-chrome-stable_current_amd.64.deb
Reading package lists... Done
Unsupported file ./google-chrome-stable_current_amd.64.deb given on commandline
Note, selecting 'google-chrome-stable:amd64' instead of './google-chrome-stable_current_amd64.deb'
Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming.
google-chrome-stable:amd64 : Depends: libasound2:amd64 (>= 1.0.16) but it is not installable
                      Depends: libatk-bridge2.0-0:amd64 (>= 2.5.3) but it is not installable
Recommends:: command not found
ubuntu@ip-:~$ E: Unable to correct problems, you have held broken packages.
E:: command not found
Jhanvi
