I have a Samsung Galaxy Book Flex2 Alpha with an Intel AX201 WiFi card dualbooting Windows 10 and Ubuntu 20.04 (now 21.04). In Windows, the WiFi card works just fine, but it doesn't work in Ubuntu.
lspci and lshw both recognize it.
I have tried disabling Windows' "fast boot" feature, as well as using version 21.04. I also apt upgraded linux-firmware, with no useful results. sudo dmesg | grep iwl shows a message like No suitable firmware found!.
Any help would be much appreciated. Thank you very much. I'm a total Linux noob, but I'm comfortable with the Unix shell.
Edit:
ls -al /boot
total 161996
drwxr-xr-x 4 root root 4096 Sep 18 18:41 .
drwxr-xr-x 20 root root 4096 Sep 18 17:18 ..
-rw-r--r-- 1 root root 252994 Apr 14 12:31 config-5.11.0-16-generic
-rw-r--r-- 1 root root 253064 Aug 26 11:11 config-5.11.0-34-generic
drwx------ 5 root root 4096 Dec 31 1969 efi
drwxr-xr-x 4 root root 4096 Sep 18 17:22 grub
lrwxrwxrwx 1 root root 28 Sep 18 17:21 initrd.img -> initrd.img-5.11.0-34-generic
-rw-r--r-- 1 root root 61665417 Sep 18 18:41 initrd.img-5.11.0-16-generic
-rw-r--r-- 1 root root 61691353 Sep 18 18:41 initrd.img-5.11.0-34-generic
lrwxrwxrwx 1 root root 28 Sep 18 17:17 initrd.img.old -> initrd.img-5.11.0-16-generic
-rw-r--r-- 1 root root 182704 Aug 18 2020 memtest86+.bin
-rw-r--r-- 1 root root 184380 Aug 18 2020 memtest86+.elf
-rw-r--r-- 1 root root 184884 Aug 18 2020 memtest86+_multiboot.bin
-rw------- 1 root root 5968084 Apr 14 12:31 System.map-5.11.0-16-generic
-rw------- 1 root root 5973530 Aug 26 11:11 System.map-5.11.0-34-generic
lrwxrwxrwx 1 root root 25 Sep 18 17:21 vmlinuz -> vmlinuz-5.11.0-34-generic
-rw-r--r-- 1 root root 14732384 Apr 20 04:13 vmlinuz-5.11.0-16-generic
-rw------- 1 root root 14752320 Aug 26 11:29 vmlinuz-5.11.0-34-generic
lrwxrwxrwx 1 root root 25 Sep 18 17:21 vmlinuz.old -> vmlinuz-5.11.0-16-generic
dkms status
backport-iwlwifi, 8613, 5.11.0-16-generic, x86_64: installed
modinfo iwlwifi
filename: /lib/modules/5.11.0-16-generic/updates/dkms/iwlwifi.ko
version: iwlwifi-stack-public:master:8613:3ae69204
license: GPL
author: Intel Corporation <linuxwifi@intel.com>
description: Intel(R) Wireless WiFi driver for Linux
firmware: iwlwifi-7265D-29.ucode
firmware: iwlwifi-7265-17.ucode
firmware: iwlwifi-3168-29.ucode
firmware: iwlwifi-3160-17.ucode
firmware: iwlwifi-7260-17.ucode
firmware: iwlwifi-8265-36.ucode
firmware: iwlwifi-8000C-36.ucode
firmware: iwlwifi-9260-th-b0-jf-b0-46.ucode
firmware: iwlwifi-9000-pu-b0-jf-b0-46.ucode
firmware: iwlwifi-ma-a0-mr-a0-57.ucode
firmware: iwlwifi-ma-a0-gf-a0-57.ucode
firmware: iwlwifi-SoSnj-a0-hr-b0-57.ucode
firmware: iwlwifi-SoSnj-a0-gf-a0-57.ucode
firmware: iwlwifi-SoSnj-a0-gf4-a0-57.ucode
firmware: iwlwifi-ty-a0-gf-a0-57.ucode
firmware: iwlwifi-so-a0-gf-a0-57.ucode
firmware: iwlwifi-so-a0-hr-b0-57.ucode
firmware: iwlwifi-so-a0-jf-b0-57.ucode
firmware: iwlwifi-cc-a0-57.ucode
firmware: iwlwifi-QuQnj-b0-jf-b0-57.ucode
firmware: iwlwifi-QuZ-a0-jf-b0-57.ucode
firmware: iwlwifi-QuZ-a0-hr-b0-57.ucode
firmware: iwlwifi-Qu-b0-jf-b0-57.ucode
firmware: iwlwifi-Qu-c0-hr-b0-57.ucode
firmware: iwlwifi-QuQnj-b0-hr-b0-57.ucode
firmware: iwlwifi-Qu-b0-hr-b0-57.ucode
srcversion: ED4BD9B69E28F43AB437F6B
---snipped, see previous edits---
depends: compat,cfg80211
retpoline: Y
vermagic: 5.11.0-16-generic SMP mod_unload modversions
sig_id: PKCS#7
signer: ubuntu Secure Boot Module Signature key
sig_key: 1A:99:03:76:D5:67:5F:C3:82:6C:33:86:8B:67:5E:40:9D:00:FA:1D
sig_hashalgo: sha512
signature: 1C:3C:D8:5B:74:91:ED:82:50:29:6C:86:5E:6A:59:0A:48:8A:8D:D9:
AF:4C:25:A6:B4:A7:84:DF:18:34:16:03:52:0E:71:76:27:EC:A1:26:
56:82:E0:EF:B0:A6:B4:39:00:DD:CC:55:21:DA:1A:15:58:52:AF:F4:
B4:9B:36:52:55:B0:43:D8:D3:09:C5:9F:76:FC:32:50:7E:71:FE:91:
BD:BD:9E:DA:E6:3D:54:C7:47:92:15:C5:DE:04:2D:68:37:28:78:40:
DC:27:54:F8:CC:2F:6E:B5:98:B9:59:F1:CE:29:5B:51:B8:04:F7:3C:
43:D0:A6:57:7E:72:B8:32:92:A9:97:85:56:E9:A6:0E:B4:75:53:7C:
05:9B:B9:BA:1F:98:AB:91:96:B5:F6:8A:97:52:7A:14:9F:1D:7C:44:
4C:38:52:BF:31:13:32:73:F0:AA:AA:CC:BB:7A:8C:8F:DC:CB:90:5B:
F5:FB:93:DC:B9:D9:8D:EE:04:E7:1A:2D:65:5E:24:72:E6:A5:6B:E2:
DA:C4:83:21:43:11:DE:AF:36:66:07:C5:27:E2:98:D2:E1:F9:0E:92:
8F:6E:04:61:1E:73:3D:C5:EC:0F:7E:D1:40:A4:65:2A:DB:EE:EC:7B:
FA:70:19:6F:0C:A0:F3:E4:48:D7:0B:2D:69:FC:FA:D8
parm: debug:debug output mask (uint)
parm: xvt_default_mode:xVT is the default operation mode (default: false) (bool)
parm: swcrypto:using crypto in software (default 0 [hardware]) (int)
parm: 11n_disable:disable 11n functionality, bitmap: 1: full, 2: disable agg TX, 4: disable agg RX, 8 enable agg TX (uint)
parm: amsdu_size:amsdu size 0: 12K for multi Rx queue devices, 2K for AX210 devices, 4K for other devices 1:4K 2:8K 3:12K 4: 2K (default 0) (int)
parm: fw_restart:restart firmware in case of error (default true) (bool)
parm: nvm_file:NVM file name (charp)
parm: uapsd_disable:disable U-APSD functionality bitmap 1: BSS 2: P2P Client (default: 3) (uint)
parm: enable_ini:Enable debug INI TLV FW debug infrastructure (default: true (bool)
parm: bt_coex_active:enable wifi/bt co-exist (default: enable) (bool)
parm: led_mode:0=system default, 1=On(RF On)/Off(RF Off), 2=blinking, 3=Off (default: 0) (int)
parm: power_save:enable WiFi power management (default: disable) (bool)
parm: power_level:default power save level (range from 1 - 5, default: 1) (int)
parm: disable_11ac:Disable VHT capabilities (default: false) (bool)
parm: disable_11ax:Disable HE capabilities (default: false) (bool)
parm: disable_msix:Disable MSI-X and use MSI instead (default: false) (bool)
parm: remove_when_gone:Remove dev from PCIe bus if it is deemed inaccessible (default: false) (bool)
Edit 2
drv.c
IWL_DEV_INFO(0x43F0, 0x0078, iwl_ax201_cfg_qu_hr, NULL),
IWL_DEV_INFO(0x43F0, 0x007C, iwl_ax201_cfg_qu_hr, NULL),
IWL_DEV_INFO(0x43F0, 0x2074, iwl_ax201_cfg_qu_hr, NULL),
IWL_DEV_INFO(0x43F0, 0x4070, iwl_ax201_cfg_qu_hr, NULL),
IWL_DEV_INFO(0xA0F0, 0x0070, iwl_ax201_cfg_qu_hr, NULL),
IWL_DEV_INFO(0xA0F0, 0x0074, iwl_ax201_cfg_qu_hr, NULL),
IWL_DEV_INFO(0xA0F0, 0x0078, iwl_ax201_cfg_qu_hr, NULL),
IWL_DEV_INFO(0xA0F0, 0x007C, iwl_ax201_cfg_qu_hr, NULL),
IWL_DEV_INFO(0xA0F0, 0x0A10, iwl_ax201_cfg_qu_hr, NULL),
IWL_DEV_INFO(0xA0F0, 0x1651, killer1650s_2ax_cfg_qu_b0_hr_b0, NULL),
IWL_DEV_INFO(0xA0F0, 0x1652, killer1650i_2ax_cfg_qu_b0_hr_b0, NULL),
IWL_DEV_INFO(0xA0F0, 0x2074, iwl_ax201_cfg_qu_hr, NULL),
IWL_DEV_INFO(0xA0F0, 0x4070, iwl_ax201_cfg_qu_hr, NULL),
// START AJS256 CHANGES
IWL_DEV_INFO(0xA0F0, 0x6074, iwl_ax201_cfg_qu_hr, NULL),
// END CHANGES
IWL_DEV_INFO(0x02F0, 0x0070, iwl_ax201_cfg_quz_hr, NULL),
IWL_DEV_INFO(0x02F0, 0x0074, iwl_ax201_cfg_quz_hr, NULL),
IWL_DEV_INFO(0x02F0, 0x0078, iwl_ax201_cfg_quz_hr, NULL),
IWL_DEV_INFO(0x02F0, 0x007C, iwl_ax201_cfg_quz_hr, NULL),
IWL_DEV_INFO(0x02F0, 0x0310, iwl_ax201_cfg_quz_hr, NULL),
IWL_DEV_INFO(0x02F0, 0x1651, iwl_ax1650s_cfg_quz_hr, NULL),
IWL_DEV_INFO(0x02F0, 0x1652, iwl_ax1650i_cfg_quz_hr, NULL),
IWL_DEV_INFO(0x02F0, 0x2074, iwl_ax201_cfg_quz_hr, NULL),
IWL_DEV_INFO(0x02F0, 0x4070, iwl_ax201_cfg_quz_hr, NULL),
IWL_DEV_INFO(0x06F0, 0x0070, iwl_ax201_cfg_quz_hr, NULL),
IWL_DEV_INFO(0x06F0, 0x0074, iwl_ax201_cfg_quz_hr, NULL),
IWL_DEV_INFO(0x06F0, 0x0078, iwl_ax201_cfg_quz_hr, NULL),
IWL_DEV_INFO(0x06F0, 0x007C, iwl_ax201_cfg_quz_hr, NULL),
IWL_DEV_INFO(0x06F0, 0x0310, iwl_ax201_cfg_quz_hr, NULL),
IWL_DEV_INFO(0x06F0, 0x1651, iwl_ax1650s_cfg_quz_hr, NULL),
IWL_DEV_INFO(0x06F0, 0x1652, iwl_ax1650i_cfg_quz_hr, NULL),
IWL_DEV_INFO(0x06F0, 0x2074, iwl_ax201_cfg_quz_hr, NULL),
IWL_DEV_INFO(0x06F0, 0x4070, iwl_ax201_cfg_quz_hr, NULL),
IWL_DEV_INFO(0x34F0, 0x0070, iwl_ax201_cfg_qu_hr, NULL),
syslog
Sep 18 17:26:29 lap-ubuntu kernel: [ 3.151659] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
Sep 18 17:26:29 lap-ubuntu kernel: [ 3.187710] iwlwifi: No config found for PCI dev a0f0/6074, rev=0x354, rfid=0x10a100
Sep 18 17:26:29 lap-ubuntu kernel: [ 3.202378] iwlwifi: probe of 0000:00:14.3 failed with error -22
Sep 18 18:43:15 lap-ubuntu kernel: [ 3.113952] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
Sep 18 18:43:15 lap-ubuntu kernel: [ 3.131228] iwlwifi: No config found for PCI dev a0f0/6074, rev=0x354, rfid=0x10a100
Sep 18 18:43:15 lap-ubuntu kernel: [ 3.150043] iwlwifi: probe of 0000:00:14.3 failed with error -22
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.060787] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078324] iwlwifi 0000:00:14.3: Direct firmware load for (efault)128.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078341] iwlwifi 0000:00:14.3: Direct firmware load for (efault)127.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078353] iwlwifi 0000:00:14.3: Direct firmware load for (efault)126.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078367] iwlwifi 0000:00:14.3: Direct firmware load for (efault)125.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078452] iwlwifi 0000:00:14.3: Direct firmware load for (efault)124.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078466] iwlwifi 0000:00:14.3: Direct firmware load for (efault)123.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078478] iwlwifi 0000:00:14.3: Direct firmware load for (efault)122.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078488] iwlwifi 0000:00:14.3: Direct firmware load for (efault)121.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078500] iwlwifi 0000:00:14.3: Direct firmware load for (efault)120.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078511] iwlwifi 0000:00:14.3: Direct firmware load for (efault)119.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078599] iwlwifi 0000:00:14.3: Direct firmware load for (efault)118.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078614] iwlwifi 0000:00:14.3: Direct firmware load for (efault)117.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078628] iwlwifi 0000:00:14.3: Direct firmware load for (efault)116.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078641] iwlwifi 0000:00:14.3: Direct firmware load for (efault)115.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078654] iwlwifi 0000:00:14.3: Direct firmware load for (efault)114.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078667] iwlwifi 0000:00:14.3: Direct firmware load for (efault)113.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078680] iwlwifi 0000:00:14.3: Direct firmware load for (efault)112.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078694] iwlwifi 0000:00:14.3: Direct firmware load for (efault)111.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078707] iwlwifi 0000:00:14.3: Direct firmware load for (efault)110.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078718] iwlwifi 0000:00:14.3: Direct firmware load for (efault)109.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078730] iwlwifi 0000:00:14.3: Direct firmware load for (efault)108.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078743] iwlwifi 0000:00:14.3: Direct firmware load for (efault)107.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078755] iwlwifi 0000:00:14.3: Direct firmware load for (efault)106.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078768] iwlwifi 0000:00:14.3: Direct firmware load for (efault)105.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078781] iwlwifi 0000:00:14.3: Direct firmware load for (efault)104.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078793] iwlwifi 0000:00:14.3: Direct firmware load for (efault)103.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078805] iwlwifi 0000:00:14.3: Direct firmware load for (efault)102.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078817] iwlwifi 0000:00:14.3: Direct firmware load for (efault)101.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078829] iwlwifi 0000:00:14.3: Direct firmware load for (efault)100.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078841] iwlwifi 0000:00:14.3: Direct firmware load for (efault)99.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078853] iwlwifi 0000:00:14.3: Direct firmware load for (efault)98.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078866] iwlwifi 0000:00:14.3: Direct firmware load for (efault)97.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078888] iwlwifi 0000:00:14.3: Direct firmware load for (efault)96.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078899] iwlwifi 0000:00:14.3: Direct firmware load for (efault)95.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078910] iwlwifi 0000:00:14.3: Direct firmware load for (efault)94.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078920] iwlwifi 0000:00:14.3: Direct firmware load for (efault)93.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078931] iwlwifi 0000:00:14.3: Direct firmware load for (efault)92.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078942] iwlwifi 0000:00:14.3: Direct firmware load for (efault)91.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078953] iwlwifi 0000:00:14.3: Direct firmware load for (efault)90.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078964] iwlwifi 0000:00:14.3: Direct firmware load for (efault)89.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078975] iwlwifi 0000:00:14.3: Direct firmware load for (efault)88.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078986] iwlwifi 0000:00:14.3: Direct firmware load for (efault)87.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.078997] iwlwifi 0000:00:14.3: Direct firmware load for (efault)86.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079007] iwlwifi 0000:00:14.3: Direct firmware load for (efault)85.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079018] iwlwifi 0000:00:14.3: Direct firmware load for (efault)84.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079029] iwlwifi 0000:00:14.3: Direct firmware load for (efault)83.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079041] iwlwifi 0000:00:14.3: Direct firmware load for (efault)82.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079055] iwlwifi 0000:00:14.3: Direct firmware load for (efault)81.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079068] iwlwifi 0000:00:14.3: Direct firmware load for (efault)80.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079082] iwlwifi 0000:00:14.3: Direct firmware load for (efault)79.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079096] iwlwifi 0000:00:14.3: Direct firmware load for (efault)78.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079109] iwlwifi 0000:00:14.3: Direct firmware load for (efault)77.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079122] iwlwifi 0000:00:14.3: Direct firmware load for (efault)76.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079135] iwlwifi 0000:00:14.3: Direct firmware load for (efault)75.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079146] iwlwifi 0000:00:14.3: Direct firmware load for (efault)74.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079158] iwlwifi 0000:00:14.3: Direct firmware load for (efault)73.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079171] iwlwifi 0000:00:14.3: Direct firmware load for (efault)72.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079184] iwlwifi 0000:00:14.3: Direct firmware load for (efault)71.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079196] iwlwifi 0000:00:14.3: Direct firmware load for (efault)70.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079208] iwlwifi 0000:00:14.3: Direct firmware load for (efault)69.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079221] iwlwifi 0000:00:14.3: Direct firmware load for (efault)68.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079233] iwlwifi 0000:00:14.3: Direct firmware load for (efault)67.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079248] iwlwifi 0000:00:14.3: Direct firmware load for (efault)66.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079260] iwlwifi 0000:00:14.3: Direct firmware load for (efault)65.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079273] iwlwifi 0000:00:14.3: Direct firmware load for (efault)64.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079292] iwlwifi 0000:00:14.3: Direct firmware load for (efault)63.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079310] iwlwifi 0000:00:14.3: Direct firmware load for (efault)62.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079328] iwlwifi 0000:00:14.3: Direct firmware load for (efault)61.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079346] iwlwifi 0000:00:14.3: Direct firmware load for (efault)60.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079358] iwlwifi 0000:00:14.3: Direct firmware load for (efault)59.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079370] iwlwifi 0000:00:14.3: Direct firmware load for (efault)58.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079383] iwlwifi 0000:00:14.3: Direct firmware load for (efault)57.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079397] iwlwifi 0000:00:14.3: Direct firmware load for (efault)56.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079408] iwlwifi 0000:00:14.3: Direct firmware load for (efault)55.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079420] iwlwifi 0000:00:14.3: Direct firmware load for (efault)54.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079431] iwlwifi 0000:00:14.3: Direct firmware load for (efault)53.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079444] iwlwifi 0000:00:14.3: Direct firmware load for (efault)52.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079457] iwlwifi 0000:00:14.3: Direct firmware load for (efault)51.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079468] iwlwifi 0000:00:14.3: Direct firmware load for (efault)50.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079480] iwlwifi 0000:00:14.3: Direct firmware load for (efault)49.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079492] iwlwifi 0000:00:14.3: Direct firmware load for (efault)48.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079504] iwlwifi 0000:00:14.3: Direct firmware load for (efault)47.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079517] iwlwifi 0000:00:14.3: Direct firmware load for (efault)46.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079528] iwlwifi 0000:00:14.3: Direct firmware load for (efault)45.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079541] iwlwifi 0000:00:14.3: Direct firmware load for (efault)44.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079552] iwlwifi 0000:00:14.3: Direct firmware load for (efault)43.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079564] iwlwifi 0000:00:14.3: Direct firmware load for (efault)42.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079576] iwlwifi 0000:00:14.3: Direct firmware load for (efault)41.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079591] iwlwifi 0000:00:14.3: Direct firmware load for (efault)40.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079605] iwlwifi 0000:00:14.3: Direct firmware load for (efault)39.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079618] iwlwifi 0000:00:14.3: Direct firmware load for (efault)38.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079631] iwlwifi 0000:00:14.3: Direct firmware load for (efault)37.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079644] iwlwifi 0000:00:14.3: Direct firmware load for (efault)36.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079656] iwlwifi 0000:00:14.3: Direct firmware load for (efault)35.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079668] iwlwifi 0000:00:14.3: Direct firmware load for (efault)34.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079680] iwlwifi 0000:00:14.3: Direct firmware load for (efault)33.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079692] iwlwifi 0000:00:14.3: Direct firmware load for (efault)32.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079705] iwlwifi 0000:00:14.3: Direct firmware load for (efault)31.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079719] iwlwifi 0000:00:14.3: Direct firmware load for (efault)30.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079731] iwlwifi 0000:00:14.3: Direct firmware load for (efault)29.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079743] iwlwifi 0000:00:14.3: Direct firmware load for (efault)28.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079756] iwlwifi 0000:00:14.3: Direct firmware load for (efault)27.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079767] iwlwifi 0000:00:14.3: Direct firmware load for (efault)26.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079779] iwlwifi 0000:00:14.3: Direct firmware load for (efault)25.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079792] iwlwifi 0000:00:14.3: Direct firmware load for (efault)24.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079803] iwlwifi 0000:00:14.3: Direct firmware load for (efault)23.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079816] iwlwifi 0000:00:14.3: Direct firmware load for (efault)22.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079828] iwlwifi 0000:00:14.3: Direct firmware load for (efault)21.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079841] iwlwifi 0000:00:14.3: Direct firmware load for (efault)20.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079853] iwlwifi 0000:00:14.3: Direct firmware load for (efault)19.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079865] iwlwifi 0000:00:14.3: Direct firmware load for (efault)18.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079877] iwlwifi 0000:00:14.3: Direct firmware load for (efault)17.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079889] iwlwifi 0000:00:14.3: Direct firmware load for (efault)16.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079911] iwlwifi 0000:00:14.3: Direct firmware load for (efault)15.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079923] iwlwifi 0000:00:14.3: Direct firmware load for (efault)14.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079935] iwlwifi 0000:00:14.3: Direct firmware load for (efault)13.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079947] iwlwifi 0000:00:14.3: Direct firmware load for (efault)12.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079959] iwlwifi 0000:00:14.3: Direct firmware load for (efault)11.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079971] iwlwifi 0000:00:14.3: Direct firmware load for (efault)10.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079985] iwlwifi 0000:00:14.3: Direct firmware load for (efault)9.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.079997] iwlwifi 0000:00:14.3: Direct firmware load for (efault)8.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.080009] iwlwifi 0000:00:14.3: Direct firmware load for (efault)7.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.080021] iwlwifi 0000:00:14.3: Direct firmware load for (efault)6.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.080034] iwlwifi 0000:00:14.3: Direct firmware load for (efault)5.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.080045] iwlwifi 0000:00:14.3: Direct firmware load for (efault)4.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.080057] iwlwifi 0000:00:14.3: Direct firmware load for (efault)3.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.080069] iwlwifi 0000:00:14.3: Direct firmware load for (efault)2.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.080081] iwlwifi 0000:00:14.3: Direct firmware load for (efault)1.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.080094] iwlwifi 0000:00:14.3: Direct firmware load for (efault)0.ucode failed with error -2
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.080095] iwlwifi 0000:00:14.3: no suitable firmware found!
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.080098] iwlwifi 0000:00:14.3: minimum version required: (efault)0
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.080100] iwlwifi 0000:00:14.3: maximum version supported: (efault)128
Sep 18 18:45:25 lap-ubuntu kernel: [ 3.080101] iwlwifi 0000:00:14.3: check git://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
Sep 18 18:49:46 lap-ubuntu dbus-daemon[20011]: [session uid=0 pid=20009] Activating service name='org.a11y.Bus' requested by ':1.1' (uid=0 pid=20005 comm="gedit /usr/src/backport-iwlwifi-8613/dkms.conf " label="unconfined")
Sep 18 18:49:46 lap-ubuntu dbus-daemon[20011]: [session uid=0 pid=20009] Activating service name='org.freedesktop.portal.Desktop' requested by ':1.0' (uid=0 pid=20005 comm="gedit /usr/src/backport-iwlwifi-8613/dkms.conf " label="unconfined")
Sep 18 19:51:27 lap-ubuntu kernel: [ 3.013496] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
Sep 18 19:51:27 lap-ubuntu kernel: [ 3.019135] iwlwifi: No config found for PCI dev a0f0/6074, rev=0x354, rfid=0x10a100
Sep 18 19:51:27 lap-ubuntu kernel: [ 3.020289] iwlwifi: probe of 0000:00:14.3 failed with error -22
Sep 18 19:50:50 lap-ubuntu kernel: [ 3.061994] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
Sep 18 19:50:50 lap-ubuntu kernel: [ 3.063454] iwlwifi: No config found for PCI dev a0f0/6074, rev=0x354, rfid=0x10a100
Sep 18 19:50:50 lap-ubuntu kernel: [ 3.064832] iwlwifi: probe of 0000:00:14.3 failed with error -22
Sep 18 19:52:34 lap-ubuntu dbus-daemon[1923]: [session uid=0 pid=1921] Activating service name='org.a11y.Bus' requested by ':1.1' (uid=0 pid=1917 comm="gedit /usr/src/backport-iwlwifi-8613/drivers/net/w" label="unconfined")
Sep 18 19:52:34 lap-ubuntu dbus-daemon[1923]: [session uid=0 pid=1921] Activating service name='org.freedesktop.portal.Desktop' requested by ':1.0' (uid=0 pid=1917 comm="gedit /usr/src/backport-iwlwifi-8613/drivers/net/w" label="unconfined")
dkms.conf lines
#OBSOLETE_BY="5.4.0"
