Pretty much everything seems to be working fine except the gnome settings application. Selecting, for instance, the "display settings" under the right top menu on the desktop does not open the settings window as it used to do. I quickly realized that gnome-control-center is not installed and I run sudo apt install gnome-control-center to install it. I got
Reading package lists... Done
Building dependency tree... Done
The following packages have unmet dependencies: libpython3.9 : Depends: libpython3.9-stdlib (= 3.9.5-3~21.04) but 3.9.7-1+focal1 is to be installed E: Unable to correct problems, you have held broken packages.
Long story short, I have 4 python3.9 packages from focal:
$ apt list --installed | grep python |grep -v "hirsute"
libpython3.9-minimal/now 3.9.7-1+focal1 amd64 [installed,local] libpython3.9-stdlib/now 3.9.7-1+focal1 amd64 [installed,local] python3.9-minimal/now 3.9.7-1+focal1 amd64 [installed,local] python3.9/now 3.9.7-1+focal1 amd64 [installed,local]
Needless to say, the rest are there and they are hirsute.
Am I to download the hirsute version of these packages and install with dpkg -i --force-all or is there another, possibly easier way?
Aslan
I was able to resolve the issue by downlading the correct packages and installing them with dpkg:
wget http://security.ubuntu.com/ubuntu/pool/main/p/python3.9/libpython3.9-stdlib_3.9.5-3~21.04_amd64.deb
wget http://nl.archive.ubuntu.com/ubuntu/pool/main/m/mpdecimal/libmpdec3_2.5.1-2_amd64.deb
wget http://security.ubuntu.com/ubuntu/pool/main/p/python3.9/python3.9-minimal_3.9.5-3~21.04_amd64.deb
wget http://security.ubuntu.com/ubuntu/pool/main/p/python3.9/python3.9_3.9.5-3~21.04_amd64.deb
dpkg -i libmpdec3_2.5.1-2_amd64.deb dpkg -i libpython3.9-stdlib_3.9.5-3~21.04_amd64.deb dpkg -i python3.9-minimal_3.9.5-3~21.04_amd64.deb dpkg -i python3.9_3.9.5-3~21.04_amd64.deb
libmpdec3 was shown as a missing dependency when I tried to install the libpython3.9-stdlib so I installed that as well. The more the merry :)
Aslan
