Good Morning, I need to force my SSH server to deny any connection which doesn't have my private SSH key... and not to ask a password
My /etc/ssh/sshd_config:
Include /etc/ssh/sshd_config.d/*.conf
Port 22 #AddressFamily any #ListenAddress 0.0.0.0 #ListenAddress ::
#HostKey /etc/ssh/ssh_host_rsa_key #HostKey /etc/ssh/ssh_host_ecdsa_key #HostKey /etc/ssh/ssh_host_ed25519_key
Ciphers and keying
#RekeyLimit default none
Logging
#SyslogFacility AUTH #LogLevel INFO
Authentication:
#LoginGraceTime 2m #PermitRootLogin prohibit-password #StrictModes yes #MaxAuthTries 7 #MaxSessions 3
PubkeyAuthentication no
Expect .ssh/authorized_keys2 to be disregarded by default in future.
AuthorizedKeysFile ~/.ssh/authorized_keys ~/.ssh/authorized_keys2
#AuthorizedPrincipalsFile none
#AuthorizedKeysCommand none #AuthorizedKeysCommandUser nobody
For this to work you will also need host keys in /etc/ssh/ssh_known_hosts
#HostbasedAuthentication no
Change to yes if you don't trust ~/.ssh/known_hosts for
#IgnoreUserKnownHosts no
Don't read the user's ~/.rhosts and ~/.shosts files
#IgnoreRhosts yes
To disable tunneled clear text passwords, change to no here!
PasswordAuthentication no PermitEmptyPasswords no
Change to yes to enable challenge-response passwords (beware issues with
some PAM modules and threads)
ChallengeResponseAuthentication no
Kerberos options
#KerberosAuthentication no #KerberosOrLocalPasswd yes #KerberosTicketCleanup yes #KerberosGetAFSToken no
GSSAPI options
#GSSAPIAuthentication no #GSSAPICleanupCredentials yes #GSSAPIStrictAcceptorCheck yes #GSSAPIKeyExchange no
Set this to 'yes' to enable PAM authentication, account processing,
and session processing. If this is enabled, PAM authentication will
be allowed through the ChallengeResponseAuthentication and
PasswordAuthentication. Depending on your PAM configuration,
PAM authentication via ChallengeResponseAuthentication may bypass
the setting of "PermitRootLogin without-password".
If you just want the PAM account and session checks to run without
PAM authentication, then enable this but set PasswordAuthentication
and ChallengeResponseAuthentication to 'no'.
UsePAM yes
#AllowAgentForwarding yes #AllowTcpForwarding yes #GatewayPorts no X11Forwarding yes #X11DisplayOffset 10 #X11UseLocalhost yes #PermitTTY yes PrintMotd no #PrintLastLog yes #TCPKeepAlive yes #PermitUserEnvironment no #Compression delayed #ClientAliveInterval 0 #ClientAliveCountMax 3 #UseDNS no #PidFile /var/run/sshd.pid #MaxStartups 10:30:100 #PermitTunnel no #ChrootDirectory none #VersionAddendum none
no default banner path
#Banner none
Allow client to pass locale environment variables
AcceptEnv LANG LC_*
override default of no subsystems
Subsystem sftp /usr/lib/openssh/sftp-server
Example of overriding settings on a per-user basis
#Match User anoncvs
X11Forwarding no
AllowTcpForwarding no
PermitTTY no
ForceCommand cvs server
Match Address 127.0.0.* PubkeyAuthentication yes
Match Address 192.168.1.* PubkeyAuthentication yes
when i try ssh -i "/path/to/ssh-key-private.txt" john@localhost it results in
john@localhost's password:
Permission denied, please try again.
Received disconnect from ::1 port 22:2: Too many authentication failures
Disconnected from ::1 port 22
and when i change PubkeyAuthentication to yes
john@localhost: Permission denied (publickey)
please note that i had already tried the following https://askubuntu.com/a/974566/1067284 https://askubuntu.com/a/1335082/1067284 and nothing worked...
Zorono
  • 61
