I wanted to do a full install of Lubuntu on a USB stick but after reading about the risk of messing up the internal drive, found the following link but it is for Ubuntu. It looks like a less risky way to get a full install onto an external drive.
Is there a similar image like this for Lubuntu that I can download? Thanks in advance.
Easy Full Install USB that Boots both BIOS and UEFI
groot
BIOS/UEFI Boot Partitions for Full Install Ubuntu and Flavours
Sudodus provides a BIOS/UEFI GRUB Template Image that can be used for Full installs as well as booting ISO files
See BIOS/UEFI Template Image for Booting ISO Files for some background.
Here is how to use it for Full installs:
  • Download the image: https://phillw.net/isos/linux-tools/uefi-n-bios/dd_grub-boot-template-for-uefi-n-bios.img.xz
  • Flash dd_grub-boot-template-for-uefi-n-bios.img to a USB using Rufus, Etcher, Gnome-Disks, mkusb or etc. (Use 7zip to extract from xz if necessary).
  • Boot a Live USB of the Ubuntu flavour you want to install, in this case Lubuntu.
  • Proceed with installation and choose the Something else option.
  • Under Device for boot loader installation select the target USB drive.
  • Select the USB free space and click +, select use as Ext4, select format this partition, and Mount point = "/" then OK. (Leave a bit of space to the right if you want a Data partition).
  • If asked to Write previous changes... click Continue.
  • Confirm the only partition to be formatted is the one just created. If asked, click continue.
  • Select your location. click "Continue"
  • Insert your name, computer name, username, password and select if you want to log in automatically or require a password.
  • Click "Continue".
  • Wait until install is complete.
  • Copy /boot/grub/grub.cfg from sdx3 to overwrite /boot/grub/grub.cfg on sdx2.
  • You can add a new FAT32 or NTFS partition for data if you wish.
C.S.Cameron
  • 20,530
  • 78
  • 125
