I just want to count all the files in a directory. I used two method what I found:
  1. tree /home/bkp Whit this method the output is 2177879 file.
  2. find /home/bkp -type f | wc -l And with that one is 2176704 file
What makes the difference? How I could count the all fille under all directories and subdirectories?
Thank you!
tree
# Also output directories but not hidden files
├── Directory1
├── Directory2
├── File1
└── File2
tree -a
# Also output hidden files and hidden directories
├── Directory1
├── Directory2
├── File1
├── File2
├── .Hidden_Directory1
├── .Hidden_Directory2
├── .Hidden_File1
└── .Hidden_File2
find -type f
# Files and hidden files
./File1
./File2
./.Hidden_File1
./.Hidden_File2
tree -aifF | grep -v '/$'
# Output files and hidden files
./File1
./File2
./.Hidden_File1
./.Hidden_File2
Source : How to make tree output only files?
The -i and -f arguments cause tree to output full paths on each line, rather than indenting. The -F argument causes it to append an / to directory names, which are filtered out by the inverted grep (grep -v '/$').
man tree
-f     Prints the full path prefix for each file.
-i     Makes tree not print the indentation lines, useful when
       used in conjunction with the -f option. Also removes as much
       whitespace as possible when used with the -J or -x options.
Gounou
  • 576
