-1
I am very new to the ubuntu os , when i tried to install php7.2-curl extension(sudo apt-get install php7.2-curl)it throws following error
 php7.2-curl : Depends: php7.2-common (= 7.2.34-23+ubuntu21.04.1+deb.sury.org+1) but 7.2.34-24+0~20210826.64+debian9~1.gbp428dfa is to be installed
i find some solution to fix this issue (sudo apt-get install libcurl13 php7.2-curl) when i run this command it shows following error ,How to resolve the issue ,Help me to fix this issue
Package libcurl3 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
  libcurl4:i386 libcurl4
E: Package 'libcurl3' has no installation candidate
libcurl3 has been replaced by libcurl4 in Ubuntu 21.04, so if you install libcurl4 Ubuntu will use it instead of libcurl3. Open the terminal and type:
sudo apt update
sudo apt install libcurl4
sudo ln -s /usr/lib/x86_64-linux-gnu/libcurl.so.4.5.0 /usr/lib/x86_64-linux-gnu/libcurl.so.4.7.0
sudo apt install php7.2-curl
karel
  • 122,292
  • 133
  • 301
  • 332
