This is the message that displays every time I try to update or install anything:
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following additional packages will be installed:
  libvdpau1
The following NEW packages will be installed:
  libvdpau1
0 upgraded, 1 newly installed, 0 to remove and 24 not upgraded.
298 not fully installed or removed.
Need to get 0 B/25.6 kB of archives.
After this operation, 109 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 162877 files and directories currently installed.)
Preparing to unpack .../libvdpau1_1.3-1ubuntu2_amd64.deb ...
Unpacking libvdpau1:amd64 (1.3-1ubuntu2) ...
dpkg: error processing archive /var/cache/apt/archives/libvdpau1_1.3-1ubuntu2_am
d64.deb (--unpack):
 trying to overwrite shared '/etc/vdpau_wrapper.cfg', which is different from ot
her instances of package libvdpau1:amd64
 /var/cache/apt/archives/libvdpau1_1.3-1ubuntu2_amd64.deb
```output of ls -la /etc/apt/sources.list.d/
Bozak
Try this:
sudo apt clean
sudo apt update
sudo apt install --reinstall libvdpau1
sudo apt --fix-broken install
Explanation:
  1. apt clean - Clean the download packages cache; this will cause the package files to be downloaded again.
  2. apt update - Update the database that stores the list of software packages
  3. apt install --reinstall libvdpau1 reinstall the package libvdpau1 that seems to be causing your issues
  4. apt --fix-broken install - Attempt to correct broken dependencies
Enterprise
  • 12,792
I would try the following:
sudo dpkg --configure -a
Also, I would remove libvdpau1 temporarily and try to get everything working with "dpkg --configure" and "apt --fix-broken". You might want to remove it with:
sudo dpkg -r --force-depends libvdpau1
This is to prevent removing anything else. Note that this will temporarily leave your package system in a broken state if there are packages that depend on libvdpau1, but your package system is in a broken state already.
Once you get things working, try reinstalling it.
The error about the Gnome PPA missing a release file seems unrelated to your current problem. It is probably due having activated a PPA after an update to a newer version (Focal) and the PPA not being configured to that new version. In general, using a PPA for something like Gnome that is an integral part of the system is not a great idea, but I digress. You should fix your /etc/apt/sources.list and /etc/apt/sources.list.d
gaussian
  • 144
