76
I'm not able to run AppImages on my Ubuntu 20.04. All the permissions are ok (see pic 1) and I have tried the terminal too (see pic 2). The messages in the terminal are dlopen(): error loading libfuse.so.2 and AppImages require FUSE to run. but fuse is already installed (see pic 3), it says fuse is already the newest version (2.9.9-3). I've tried to reinstall fuse with the --reinstall apt option, same results.
Any thoughts?
Thank you in advance :)
Permissions are ok
Tried the terminal
Fuse is already installed
5 Answers5
127
I solved the issue related to the error message:
By installing FUSE.
For Ubuntu < 22.04 use:
sudo apt-get install fuse libfuse2
For Ubuntu >= 22.04 use:
sudo apt install libfuse2
Source: https://docs.appimage.org/user-guide/troubleshooting/fuse.html
You have to download appimage for your actual CPU architecture.
The most popular is amd64. So download link for BalenaEtcher would be https://github.com/balena-io/etcher/releases/download/v1.5.122/balenaEtcher-1.5.122-x64.AppImage .
N0rbert
  • 103,263
If you are struggling to run Etcher as AppImage on Ubuntu, I suggest the proper way as the one pointed out from the authors.
Messing up with fuse / libfuse2 caused dependency hell on my Jammy host, so be careful.
dpkg: fuse3: dependency problems, but removing anyway as you requested:
 kio-fuse depends on fuse3.
 encfs depends on fuse; however:
  Package fuse is not installed.
  Package fuse3 which provides fuse is to be removed.
 cryfs depends on fuse; however:
I had the same issue while running an AppImage from the terminal.
I recommend running it within its own window via click.
Just in case anyone comes here with a similar question. Seems related to a disconnect of some kind when running from the terminal. Or there are numerous issues that are hidden when not running the terminal.
I found it necessary to remove appimagelauncher in order to run Cursor.
Trying to simply run the Cursor AppImage executable invoked the appimagelauncher startup window. Clicking invoked the following FUSE error:
Can't open squashfs image: Bad address
Cannot mount AppImage, please check your FUSE setup. You might still be able to extract the contents of this AppImage if you run it with the --appimage-extract option. See https://github.com/AppImage/AppImageKit/wiki/FUSE for more information execv error: No such file or directory
I made sure that I had libfuse2 installed (22.04 -- requires different lib for 24.04), and uninstalled appimagelauncher, and the Cursor appimage now runs.
markling
  • 593
