I was sending requests to my server using postman. Then, something went wrong and all of my requests were blocked. Now, I can't send requests or even access the server using the IP address unless I use a VPN.
I am a student learning and I am pretty lost — I don't know where to start. I searched for hours on how to reset UFW and disable and enable and even adding new rules didn't work. Below is the output from the UFW iptables. I'm sending requests through postman to the server IP.
Chain INPUT (policy DROP 21 packets, 2312 bytes)
pkts bytes target prot opt in out source destination
4739 371K ufw-before-logging-input all -- * * 0.0.0.0/0 0.0.0.0/0
4739 371K ufw-before-input all -- * * 0.0.0.0/0 0.0.0.0/0
21 2312 ufw-after-input all -- * * 0.0.0.0/0 0.0.0.0/0
21 2312 ufw-after-logging-input all -- * * 0.0.0.0/0 0.0.0.0/0
21 2312 ufw-reject-input all -- * * 0.0.0.0/0 0.0.0.0/0
21 2312 ufw-track-input all -- * * 0.0.0.0/0 0.0.0.0/0
Chain FORWARD (policy DROP 0 packets, 0 bytes)
0 0 ufw-before-logging-forward all -- * * 0.0.0.0/0 0.0.0.0/0
0 0 ufw-before-forward all -- * * 0.0.0.0/0 0.0.0.0/0
0 0 ufw-after-forward all -- * * 0.0.0.0/0 0.0.0.0/0
0 0 ufw-after-logging-forward all -- * * 0.0.0.0/0 0.0.0.0/0
0 0 ufw-reject-forward all -- * * 0.0.0.0/0 0.0.0.0/0
0 0 ufw-track-forward all -- * * 0.0.0.0/0 0.0.0.0/0
Chain OUTPUT (policy ACCEPT 0 packets, 0 bytes)
4071 6364K ufw-before-logging-output all -- * * 0.0.0.0/0 0.0.0.0/0
4071 6364K ufw-before-output all -- * * 0.0.0.0/0 0.0.0.0/0
22 1466 ufw-after-output all -- * * 0.0.0.0/0 0.0.0.0/0
22 1466 ufw-after-logging-output all -- * * 0.0.0.0/0 0.0.0.0/0
22 1466 ufw-reject-output all -- * * 0.0.0.0/0 0.0.0.0/0
22 1466 ufw-track-output all -- * * 0.0.0.0/0 0.0.0.0/0
Chain ufw-after-forward (1 references)
Chain ufw-after-input (1 references)
0 0 ufw-skip-to-policy-input udp -- * * 0.0.0.0/0 0.0.0.0/0 udp dpt:137
0 0 ufw-skip-to-policy-input udp -- * * 0.0.0.0/0 0.0.0.0/0 udp dpt:138
0 0 ufw-skip-to-policy-input tcp -- * * 0.0.0.0/0 0.0.0.0/0 tcp dpt:139
0 0 ufw-skip-to-policy-input tcp -- * * 0.0.0.0/0 0.0.0.0/0 tcp dpt:445
0 0 ufw-skip-to-policy-input udp -- * * 0.0.0.0/0 0.0.0.0/0 udp dpt:67
0 0 ufw-skip-to-policy-input udp -- * * 0.0.0.0/0 0.0.0.0/0 udp dpt:68
0 0 ufw-skip-to-policy-input all -- * * 0.0.0.0/0 0.0.0.0/0 ADDRTYPE match dst-type BROADCAST
Chain ufw-after-logging-forward (1 references)
0 0 LOG all -- * * 0.0.0.0/0 0.0.0.0/0 limit: avg 3/min burst 10 LOG flags 0 level 4 prefix "[UFW BLOCK] "
Chain ufw-after-logging-input (1 references)
21 2312 LOG all -- * * 0.0.0.0/0 0.0.0.0/0 limit: avg 3/min burst 10 LOG flags 0 level 4 prefix "[UFW BLOCK] "
Chain ufw-after-logging-output (1 references)
Chain ufw-after-output (1 references)
Chain ufw-before-forward (1 references)
0 0 ACCEPT all -- * * 0.0.0.0/0 0.0.0.0/0 ctstate RELATED,ESTABLISHED
0 0 ACCEPT icmp -- * * 0.0.0.0/0 0.0.0.0/0 icmptype 3
0 0 ACCEPT icmp -- * * 0.0.0.0/0 0.0.0.0/0 icmptype 11
0 0 ACCEPT icmp -- * * 0.0.0.0/0 0.0.0.0/0 icmptype 12
0 0 ACCEPT icmp -- * * 0.0.0.0/0 0.0.0.0/0 icmptype 8
0 0 ufw-user-forward all -- * * 0.0.0.0/0 0.0.0.0/0
Chain ufw-before-input (1 references)
444 125K ACCEPT all -- lo * 0.0.0.0/0 0.0.0.0/0
4255 243K ACCEPT all -- * * 0.0.0.0/0 0.0.0.0/0 ctstate RELATED,ESTABLISHED
5 1099 ufw-logging-deny all -- * * 0.0.0.0/0 0.0.0.0/0 ctstate INVALID
5 1099 DROP all -- * * 0.0.0.0/0 0.0.0.0/0 ctstate INVALID
0 0 ACCEPT udp -- * * 0.0.0.0/0 0.0.0.0/0 udp spt:67 dpt:68
35 3048 ufw-not-local all -- * * 0.0.0.0/0 0.0.0.0/0
0 0 ACCEPT udp -- * * 0.0.0.0/0 224.0.0.251 udp dpt:5353
0 0 ACCEPT udp -- * * 0.0.0.0/0 239.255.255.250 udp dpt:1900
35 3048 ufw-user-input all -- * * 0.0.0.0/0 0.0.0.0/0
Chain ufw-before-logging-forward (1 references)
Chain ufw-before-logging-input (1 references)
Chain ufw-before-logging-output (1 references)
Chain ufw-before-output (1 references)
444 125K ACCEPT all -- * lo 0.0.0.0/0 0.0.0.0/0
3605 6238K ACCEPT all -- * * 0.0.0.0/0 0.0.0.0/0 ctstate RELATED,ESTABLISHED
22 1466 ufw-user-output all -- * * 0.0.0.0/0 0.0.0.0/0
Chain ufw-logging-allow (0 references)
0 0 LOG all -- * * 0.0.0.0/0 0.0.0.0/0 limit: avg 3/min burst 10 LOG flags 0 level 4 prefix "[UFW ALLOW] "
Chain ufw-logging-deny (2 references)
5 1099 RETURN all -- * * 0.0.0.0/0 0.0.0.0/0 ctstate INVALID limit: avg 3/min burst 10
Chain ufw-not-local (1 references)
35 3048 RETURN all -- * * 0.0.0.0/0 0.0.0.0/0 ADDRTYPE match dst-type LOCAL
0 0 RETURN all -- * * 0.0.0.0/0 0.0.0.0/0 ADDRTYPE match dst-type MULTICAST
0 0 RETURN all -- * * 0.0.0.0/0 0.0.0.0/0 ADDRTYPE match dst-type BROADCAST
0 0 ufw-logging-deny all -- * * 0.0.0.0/0 0.0.0.0/0 limit: avg 3/min burst 10
0 0 DROP all -- * * 0.0.0.0/0 0.0.0.0/0
Chain ufw-reject-forward (1 references)
Chain ufw-reject-input (1 references)
Chain ufw-reject-output (1 references)
Chain ufw-skip-to-policy-forward (0 references)
Chain ufw-skip-to-policy-input (7 references)
Chain ufw-skip-to-policy-output (0 references)
Chain ufw-track-forward (1 references)
Chain ufw-track-input (1 references)
Chain ufw-track-output (1 references)
11 660 ACCEPT tcp -- * * 0.0.0.0/0 0.0.0.0/0 ctstate NEW
11 806 ACCEPT udp -- * * 0.0.0.0/0 0.0.0.0/0 ctstate NEW
Chain ufw-user-forward (1 references)
Chain ufw-user-input (1 references)
7 380 ACCEPT tcp -- * * 0.0.0.0/0 0.0.0.0/0 tcp dpt:22
6 316 ACCEPT tcp -- * * 0.0.0.0/0 0.0.0.0/0 tcp dpt:80
1 40 ACCEPT tcp -- * * 0.0.0.0/0 0.0.0.0/0 tcp dpt:443
0 0 ACCEPT tcp -- * * 0.0.0.0/0 0.0.0.0/0 tcp dpt:5432
0 0 ACCEPT tcp -- * * 0.0.0.0/0 0.0.0.0/0 tcp dpt:22 /* 'dapp_OpenSSH' /
0 0 ACCEPT tcp -- * 0.0.0.0/0 0.0.0.0/0 tcp dpt:80 /* 'dapp_Apache' /
0 0 ACCEPT udp -- * * 0.0.0.0/0 0.0.0.0/0 udp dpt:80
Chain ufw-user-limit (0 references)
0 0 LOG all -- * * 0.0.0.0/0 0.0.0.0/0 limit: avg 3/min burst 5 LOG flags 0 level 4 prefix "[UFW LIMIT BLOCK] "
0 0 REJECT all -- * * 0.0.0.0/0 0.0.0.0/0 reject-with icmp-port-unreachable
Chain ufw-user-limit-accept (0 references)
Chain ufw-user-logging-forward (0 references)
Chain ufw-user-logging-input (0 references)
Chain ufw-user-logging-output (0 references)
Chain ufw-user-output (1 references)
