16
The problem
Hi, I am having trouble installing the Nvidia drivers on my machine. The goal was to perform these simple commands:
$ ubuntu-drivers devices
And so, get something like:
modalias : pci:v000010DEd00001C8Csv00001028sd00000798bc03sc00i00
vendor   : NVIDIA Corporation
model    : GP107M [GeForce GTX 1050 Ti Mobile]
driver   : nvidia-driver-460 - distro non-free
driver   : nvidia-driver-418-server - distro non-free
driver   : nvidia-driver-470 - distro non-free recommended
driver   : nvidia-driver-450-server - distro non-free
driver   : nvidia-driver-460-server - distro non-free
driver   : nvidia-driver-390 - distro non-free
driver   : xserver-xorg-video-nouveau - distro free builtin
And after checking that everything was OK, just run this:
$ sudo ubuntu-drivers autoinstall
But I get this as a response inside the output of ubuntu-drivers devices and I can't do the next step sudo ubuntu-drivers autoinstall:
WARNING:root:_pkg_get_support nvidia-driver-390: package has invalid Support Legacyheader, cannot determine support level
Important note The drivers were working perfectly until today. But after the laptop ran out of battery (and it shut down because of this) the drivers, for some reason, vanished. The driver I had working and also the one I am going to try to install is the 470 from Nvidia, that is, I never installed the 390.
Attempts of solutions I already tried
I have tried several (attempted) solutions, but they don't work, such as a simple
$ sudo apt update
$ sudo apt upgrade
but it does not work, then I tried
$ sudo apt-get remove --purge nvidia*
and it doesn't work either, I also tried with the quotes
$ sudo apt-get remove --purge "nvidia*"
but it keeps failing
My configs
Ubuntu version
$ cat /etc/os-release
NAME="Ubuntu" VERSION="20.04.3 LTS (Focal Fossa)" ID=ubuntu ID_LIKE=debian PRETTY_NAME="Ubuntu 20.04.3 LTS" VERSION_ID="20.04" HOME_URL="https://www.ubuntu.com/" SUPPORT_URL="https://help.ubuntu.com/" BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/" PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy" VERSION_CODENAME=focal UBUNTU_CODENAME=focal
Kernel version
$ uname -a
Linux DellInspiron 5.11.0-34-generic #36~20.04.1-Ubuntu SMP Fri Aug 27 08:06:32 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
Drivers list
$ ubuntu-drivers list
WARNING:root:_pkg_get_support nvidia-driver-390: package has invalid Support Legacyheader, cannot determine support level nvidia-driver-450-server, (kernel modules provided by linux-modules-nvidia-450-server-generic-hwe-20.04) nvidia-driver-460-server, (kernel modules provided by linux-modules-nvidia-460-server-generic-hwe-20.04) nvidia-driver-390, (kernel modules provided by linux-modules-nvidia-390-generic-hwe-20.04) nvidia-driver-418-server, (kernel modules provided by linux-modules-nvidia-418-server-generic-hwe-20.04) nvidia-driver-470, (kernel modules provided by linux-modules-nvidia-470-generic-hwe-20.04) nvidia-driver-460, (kernel modules provided by linux-modules-nvidia-460-generic-hwe-20.04)
Devices list
WARNING:root:_pkg_get_support nvidia-driver-390: package has invalid Support Legacyheader, cannot determine support level == /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0 == modalias : pci:v000010DEd00001C8Csv00001028sd00000798bc03sc00i00 vendor : NVIDIA Corporation model : GP107M [GeForce GTX 1050 Ti Mobile] driver : nvidia-driver-460 - distro non-free driver : nvidia-driver-418-server - distro non-free driver : nvidia-driver-470 - distro non-free recommended driver : nvidia-driver-450-server - distro non-free driver : nvidia-driver-460-server - distro non-free driver : nvidia-driver-390 - distro non-free driver : xserver-xorg-video-nouveau - distro free builtin
After researching in several forums, I found a partial solution here by the user alok.fj
The steps are quite simple, I put all the steps here in order:
$ sudo apt update
$ sudo apt upgrade
$ sudo apt autoremove
Then I run (as the original idea was)
WARNING:root:_pkg_get_support nvidia-driver-390: package has invalid Support Legacyheader, cannot determine support level modalias : pci:v000010DEd00001C8Csv00001028sd00000798bc03sc00i00 vendor : NVIDIA Corporation model : GP107M [GeForce GTX 1050 Ti Mobile] driver : nvidia-driver-460 - distro non-free driver : nvidia-driver-418-server - distro non-free driver : nvidia-driver-470 - distro non-free recommended driver : nvidia-driver-450-server - distro non-free driver : nvidia-driver-460-server - distro non-free driver : nvidia-driver-390 - distro non-free driver : xserver-xorg-video-nouveau - distro free builtin
Note that I still get the WARNING, but instead of running sudo ubuntu-drivers autoinstall, run the command explicitly clarifying the desired driver version:
sudo apt install nvidia-driver-470
sudo reboot
Once you have rebooted, test the installation with nvidia-smi and you should get something like this:
$ nvidia-smi
+-----------------------------------------------------------------------------+ | NVIDIA-SMI 470.57.02 Driver Version: 470.57.02 CUDA Version: 11.4 | |-------------------------------+----------------------+----------------------+ | GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC | | Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. | | | | MIG M. | |===============================+======================+======================| | 0 NVIDIA GeForce ... Off | 00000000:01:00.0 On | N/A | | N/A 50C P0 N/A / N/A | 447MiB / 4040MiB | 1% Default | | | | N/A | +-------------------------------+----------------------+----------------------+ ...
TL; DR
$ sudo apt update
$ sudo apt upgrade
$ sudo apt install nvidia-driver-470      (you may need other version)
$ sudo reboot
Test with
$ nvidia-smi
I tried all these steps but the underlying issue was the Secure Boot was Enabled. Disabling Secure Boot did the job.
