I have a compiled program in a certain folder that I would like to access from anywhere without needing the write ./path/to/file/each/time/app_name. For example, the app executable is installed in this ./path/to/file/each/time/app_name path, and I would like to be able to open it by writing app_name in the command line, and nothing more than that. How could I do that?
Asked
Active
Viewed 58 times
pdaranda661
- 113
Create a script (as root) called /usr/local/bin/app_name and put this inside it:
#!/bin/bash
/path/to/file/app_name $@
Then make the script executable:
sudo chmod +x /usr/local/bin/app_name
Kristopher Ives
- 5,669
Create an alias for your program in the .bashrc file.
nano ~/.bashrc
At the end of the file type the line:
alias app_name=/path/to/file/each/time/app_name
Then save (CTRL+O then Enter) and exit (CTRL+X).
You will be able to use the alias in new Terminal windows you open.
Alejandro
- 745
