I just bought a Fusion Serie from PCSpecialist and I'm having screen issue when running Ubuntu (tested 20.04 and 21.04) or PopOS (tested 21.04)
  • built-in screen display is blinking when the mouse cursor is moving within its display area using the touchpad or a mouse
  • if I press the left button while moving the cursor the display does not blink
  • when using an external monitor its display is fine, but not the integrated screen one (in duplicated or extended mode)
  • I recorded the screen and the video is not showing the blinks (although the screen was blinking while recording)
What I tried:
  • changing screens resolutions
  • enabling / disabling PopOS HiDPI daemon
  • use different kernels (from 5.11 to 5.14)
Here are the laptop specs:
  • Chassis & Display: Fusion Studio Series : Écran large LED mat 14 pouces 90 Hz sRGB 95 % WQXGA (2880 x 1800)
  • Processor (CPU): Processeur Quad Core Intel® Core® i7 11370H (3,3 GHz, 4,8 GHz Turbo)
  • Memory (RAM): 16 Go Corsair 2933 MHz SODIMM DDR4 (2 x 8 Go)
  • Graphics Card: Intel® Iris® Xe Graphics
  • 1st M.2 SSD Drive: 500 Go SAMSUNG 970 EVO PLUS M.2, PCIe NVMe
And some commands outputs (from PopOS 21.04):
uname -r
5.11.0-7633-generic
inxi -G Graphics: Device-1: Intel TigerLake GT2 [Iris Xe Graphics] driver: i915 v: kernel Device-2: Chicony HD Webcam type: USB driver: uvcvideo Display: x11 server: X.Org 1.20.11 driver: loaded: modesetting unloaded: fbdev,vesa resolution: 1: 1440x900~60Hz 2: 1920x1080~60Hz OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 21.0.1
sudo lshw -c video *-display
description: VGA compatible controller product: TigerLake GT2 [Iris Xe Graphics] vendor: Intel Corporation physical id: 2 bus info: pci@0000:00:02.0 logical name: /dev/fb0 version: 01 width: 64 bits clock: 33MHz capabilities: pciexpress msi pm vga_controller bus_master cap_list rom fb configuration: depth=32 driver=i915 latency=0 mode=2880x1800 visual=truecolor xres=2880 yres=1800 resources: iomemory:600-5ff iomemory:400-3ff irq:153 memory:601c000000-601cffffff memory:4000000000-400fffffff ioport:3000(size=64) memory:c0000-dffff memory:4010000000-4016ffffff memory:4020000000-40ffffffff
lspci -nnk | grep -iA2 VGA 00:02.0 VGA compatible controller [0300]: Intel Corporation TigerLake GT2 [Iris Xe Graphics] [8086:9a49] (rev 01) DeviceName: Onboard - Video Subsystem: Tongfang Hongkong Limited Iris Xe Graphics [1d05:1105]
Full probe of my system: https://linux-hardware.org/?probe=9361e69812
I don't really know which potential fixes I should start with therefore any help will be greatly appreciated. Thanks
NOTE: I also have W10 installed along side PopOS and W10 is working fine.
Glorfindel
  • 975
  • 15
Vadb
  • 31
Just had this problem on the exact same processor. It turned out that an Intel power-optimization feature has to be turned off via grub.
Add "i915.enable_psr=0" to the default GRUB command line in /etc/defaults/grub, so it reads:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash i915.enable_psr=0"
The flickering is gone after activating this GRUB.
$ sudo update-grub
I was in the same boat as you. Same machine, same vendor and same specs. After trying so many updates and this simple workaround worked for me.
Enable fractional scaling and using 125% scaling. At least stopped the screen flickering.
Found the solution here: Cursor flickers on primary display when fractional scaling is enable for dual monitors on Ubuntu Desktop 20.04
Let me know if it solves the issue.
