15
I just have a fresh install of Kubuntu 20.04 on an Acer Swift 3 laptop. I ran into problem with transferring files from my Android phone. Here was the steps I went through:
  1. Plug the phone into USB port. The device shows up on Kubuntu (Dolphin and popup notification)
  2. Unlock the phone and accept permission.
  3. Click on the device and got the following error:
No storage media found. Make sure your device is unlocked and has MTP enabled in its USB connection settings.
When I run mtp-detect, I got the following error:
$ mtp-detect
libmtp version: 1.1.17
Listing raw device(s) Device 0 (VID=04e8 and PID=6860) is a Samsung Galaxy models (MTP). Found 1 device(s): Samsung: Galaxy models (MTP) (04e8:6860) @ bus 3, dev 11 Attempting to connect device(s) error returned by libusb_claim_interface() = -6LIBMTP PANIC: Unable to initialize device Unable to open raw device 0 OK.
dmesg:
[ 1799.438225] usb 3-1: new high-speed USB device number 16 using xhci_hcd
[ 1799.593572] usb 3-1: New USB device found, idVendor=04e8, idProduct=6860, bcdDevice= c.00
[ 1799.593575] usb 3-1: New USB device strings: Mfr=7, Product=8, SerialNumber=9
[ 1799.593576] usb 3-1: Product: SAMSUNG_Android
[ 1799.593577] usb 3-1: Manufacturer: SAMSUNG
[ 1799.593578] usb 3-1: SerialNumber: 27a0c9216c1c7ece
[ 1799.603905] cdc_acm 3-1:1.1: ttyACM0: USB ACM device
lsusb:
$ lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 003: ID 1c7a:0575 LighTuning Technology Inc. EgisTec EH575
Bus 003 Device 002: ID 0408:a094 Quanta Computer, Inc. HD User Facing
Bus 003 Device 004: ID 8087:0026 Intel Corp.
Bus 003 Device 016: ID 04e8:6860 Samsung Electronics Co., Ltd Galaxy series, misc. (MTP mode)
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
But something is really strange. It works if I do the following:
  1. Plug the phone into laptop.
  2. Boot the laptop.
  3. Once Kubuntu loaded, run $ mtp-detect. This time mtp-detect no longer reports any error.
  4. Access the phone device via Dolphin works now.
Then MTP file transfer will work, until the phone is unplugged. Replugging the phone in will not work anymore.
I really have no idea what is going on. Any help is much appreciated.
meter
  • 153
6 Answers6
10
For me, the fix was to exit Dolphin file explorer previous to connecting the phone via USB. After connecting it, I clicked on 'Mount and open' which opened Dolphin but not on my phone's storage.
After browsing to my phone's storage on the left in Dolphin, I could see the contents.
I turned off USB debugging on my android and this problem was solved.
I'm also confronted by this bug and have discovered this issue reported elsewhere:
https://bugs.mageia.org/show_bug.cgi?id=28216
And here:
https://bugs.kde.org/show_bug.cgi?id=442170
If I understand correctly, a fix is available here:
https://github.com/libusb/libusb/commit/f6d2cb561402c3b6d3627c0eb89e009b503d9067
Unfortunately, my Linux Voodoo only goes so far. I don't know how to implement this fix, but maybe you do. It might also be possible to install later versions of Libusb (the package that seems to be at issue):
https://packages.ubuntu.com/search?keywords=libusb
But I leave that to others better suited to advise. I only post this with the hope that others with more experience can explain to us how to implement the fix.
user47108
  • 354
My Kubuntu 20.04.4 (focal) LTS contained the libusb-0.1-4 and libusb-1.0.0 packages. After uninstalling libusb-0.1-4, MTP access worked quickly and satisfactorily.
I haven't solved the bug but did find a workaround that works for me.
  1. Connect the phone. Choose "This Device", then choose Data Transfer.
  2. Three options (under Plasma) will be provided. Choose Data Transfer and Dolphin will open with the error above.
  3. Choose "Connected Device" on the phone as the controlling device. Give it a minute to reset.
  4. Once it has reset, re-choose "This Device" when the option becomes available.
  5. Choose "Data Transfer" on the phone, then choose the same option from the Plasma popup.
This seems to be a reproducible workaround on my system.
user47108
  • 354
I still have problem with accessing files from dolphin file manager in Kubuntu 22.04. Created kde bug for it. https://bugs.kde.org/show_bug.cgi?id=480332
In bug description I pointed out recovery steps.
