prashant@BGRGP93:~$ microstack
microstack: command not found
Try to install with below commands
prashant@BGRGP93:~$ sudo snap install microstack --beta --devmode
[sudo] password for prashant:
error: cannot communicate with server: Post http://localhost/v2/snaps/microstack: dial unix /run/snapd.socket: connect: no such file or directory
checked online for how to fix the above error... they suggested to try below steps... but I get error while starting snapd.service
prashant@BGRGP93:~$ sudo systemctl unmask snapd.service
prashant@BGRGP93:~$ sudo systemctl enable snapd.service
prashant@BGRGP93:~$ sudo systemctl start snapd.service
System has not been booted with systemd as init system (PID 1). Can't operate.
Failed to connect to bus: Host is down
version of my system
prashant@BGRGP93:~$ cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=20.04
DISTRIB_CODENAME=focal
DISTRIB_DESCRIPTION="Ubuntu 20.04.3 LTS"
prashant@BGRGP93:~$
I get this error lot of times while installing openstack... I am using wsl2 on windows 10 ...
The same snap install works on gcp instance correctly with ubuntu 16.04
