Every command I use can’t install anything as I keep getting error code. I am using 20.04 and used commands such as
sudo add-apt-repository papa:lutris-team/lutris
sudo apt-get update
sudo apt-get install lutris
at the end of every failed download I get
Reading package lists… Done
Building dependency tree
Reading state information… Done
Correcting dependancies… Done
The following additional packages will be installed:
Libvdpaul
0 upgraded, 1 newly installed, 0 to remove and 2 not upgraded. 276 not fully installed or removed
Need to get 0 B/25.6 KB of archives
After this operation, 109 KB of additional disk space will be used.
Do you want to continue? (Y/N) I click Yes
(Reading database … 160926 files and directories currently installed.
Preparing to unpack …/libvdpau1_1.3-1ubuntu2_amd64.deb …
Unpacking libvdpau1: amd64 (1.3-1Ubuntu2) …
dpkg: error processing archive /var/cache/apt/archives/libvdpau1_1.3-1ubuntu2_amd64.deb (—unpack):
Trying to overwrite shared ‘/etc/vdpau_wrapper.cfg’, which is different from other instances of package bvdpau1:amd64
 /var /cache/ apt/ archives/ libvdpau1_1.3-1ubuntu2_amd64.deb
E:Sub-process /usr/bin/dpkg returned an error code (1)”
Tried installing Lutris and Komorebi and was unsuccessful.
N0rbert
  • 103,263
Bozak
