I installed Ubuntu 21.04 yesterday (dual booting with Windows 10) with an SSD (Samsung 970 EVO), Nvidia GPU and AMD CPU. Ubuntu takes >30 seconds to reach the login screen after selecting it on the boot menu and this is significantly longer than Windows 10 which takes <5 seconds. My BIOS splash screen also seems to be taking >10 seconds to load which is notably longer than usual. I've tried these commands to troubleshoot:
  • systemd-analyze blame:
1min 2.842s upower.service
    28.641s plymouth-quit-wait.service
     6.328s NetworkManager-wait-online.service
      887ms snapd.service
      579ms snap-snap\x2dstore-547.mount
      576ms snap-snapd-11588.mount
      547ms snap-gnome\x2d3\x2d34\x2d1804-72.mount
      467ms snap-gtk\x2dcommon\x2dthemes-1514.mount
      359ms snap-snapd-12883.mount
      349ms snap-core18-1997.mount
      345ms snap-snap\x2dstore-518.mount
      317ms dev-nvme0n1p5.device
      312ms snap-core18-2128.mount
      310ms snap-gtk\x2dcommon\x2dthemes-1515.mount
      293ms snap-gnome\x2d3\x2d34\x2d1804-66.mount
      239ms dev-loop1.device
      229ms snapd.seeded.service
      173ms dev-loop2.device
      156ms dev-loop0.device
      155ms dev-loop4.device
      140ms rtkit-daemon.service
      120ms dev-loop5.device
      115ms dev-loop7.device
      103ms dev-loop6.device
      101ms systemd-resolved.service
       82ms systemd-timesyncd.service
       81ms networkd-dispatcher.service
       79ms cups.service
       70ms apparmor.service
       70ms boot-efi.mount
       68ms dev-loop3.device
       67ms systemd-udev-trigger.service
       58ms udisks2.service
       56ms accounts-daemon.service
       47ms user@1000.service
       46ms update-notifier-download.service
       45ms gpu-manager.service
       45ms systemd-journald.service
       41ms swapfile.swap
       39ms polkit.service
       39ms avahi-daemon.service
       39ms NetworkManager.service
       38ms bluetooth.service
       32ms power-profiles-daemon.service
       31ms ModemManager.service
       31ms nvidia-persistenced.service
       31ms dev-loop8.device
       29ms switcheroo-control.service
       27ms thermald.service
       27ms keyboard-setup.service
       26ms systemd-logind.service
       25ms wpa_supplicant.service
       25ms systemd-journal-flush.service
       24ms apport.service
       23ms systemd-udevd.service
       23ms systemd-modules-load.service
       22ms systemd-tmpfiles-clean.service
       21ms gdm.service
       19ms secureboot-db.service
       18ms packagekit.service
       16ms snapd.apparmor.service
       15ms plymouth-start.service
       14ms grub-common.service
       14ms systemd-fsck@dev-disk-by\x2duuid-78FD\x2d7191.service
       14ms grub-initrd-fallback.service
       11ms e2scrub_reap.service
       11ms systemd-tmpfiles-setup.service
       11ms plymouth-read-write.service
        9ms rsyslog.service
        9ms colord.service
        8ms systemd-random-seed.service
        8ms alsa-restore.service
        7ms pppd-dns.service
        7ms systemd-sysctl.service
        6ms dev-hugepages.mount
        6ms dev-mqueue.mount
        6ms kerneloops.service
        6ms modprobe@drm.service
        6ms sys-kernel-debug.mount
        5ms user-runtime-dir@1000.service
        5ms sys-kernel-tracing.mount
        5ms systemd-rfkill.service
        5ms systemd-remount-fs.service
        4ms systemd-sysusers.service
        4ms systemd-tmpfiles-setup-dev.service
        4ms kmod-static-nodes.service
        3ms modprobe@configfs.service
        3ms systemd-update-utmp-runlevel.service
        3ms modprobe@fuse.service
        3ms dev-loop9.device
        2ms systemd-update-utmp.service
        2ms openvpn.service
        2ms systemd-user-sessions.service
        1ms console-setup.service
        1ms setvtrgb.service
        1ms ufw.service
        1ms sys-fs-fuse-connections.mount
      915us sys-kernel-config.mount
      401us snapd.socket
  • systemd-analyze time
Startup finished in 1min 2.982s (firmware) + 7.913s (loader) + 2.216s (kernel) + 1min 4.273s (userspace) = 2min 17.386s
graphical.target reached after 29.551s in userspace
  • systemd-analyze critical-chain upower.service
The time when unit became active or started is printed after the "@" character.
The time the unit took to start is printed after the "+" character.
upower.service +1min 2.842s └─dbus.socket @858ms └─basic.target @858ms └─sockets.target @858ms └─snapd.socket @857ms +401us └─sysinit.target @855ms └─systemd-timesyncd.service @773ms +82ms └─systemd-tmpfiles-setup.service @760ms +11ms └─local-fs.target @759ms └─run-user-1000-gvfs.mount @32.923s └─run-user-1000.mount @32.857s └─swap.target @196ms └─swapfile.swap @155ms +41ms └─systemd-remount-fs.service @149ms +5ms └─systemd-journald.socket @143ms └─-.mount @98ms └─-.slice @98ms
  • systemctl status upower
● upower.service - Daemon for power management
     Loaded: loaded (/lib/systemd/system/upower.service; disabled; vendor preset: enabled)
     Active: active (running) since ---
       Docs: man:upowerd(8)
   Main PID: 1174 (upowerd)
      Tasks: 3 (limit: 38334)
     Memory: 2.1M
     CGroup: /system.slice/upower.service
             └─1174 /usr/libexec/upowerd
Sep 05 13:03:11 user systemd[1]: Starting Daemon for power management... Sep 05 03:04:14 user upowerd[1174]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-2/5-2:1.2/0003:046D:C539.0006/0003:046D:407F.0008/power_supply/hidpp_battery_0 Sep 05 03:04:14 user upowerd[1174]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-2/5-2:1.2/0003:046D:C539.0006/0003:046D:407F.0008/power_supply/hidpp_battery_0 Sep 05 03:04:14 user systemd[1]: Started Daemon for power management.
  • journalctl "_SYSTEMD_UNIT=upower.service"
Sep 04 22:21:45 user upowerd[3165]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-2/5-2:1.2/0003:046D:C539.0006/0003:046D:407F.0008/power_supply/hidpp_battery_0
-- Boot c3a7df5ead774a29bf789838f8ce7a31 --
Sep 04 22:27:50 user upowerd[3113]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-2/5-2:1.2/0003:046D:C539.0006/0003:046D:407F.0008/power_supply/hidpp_battery_0
-- Boot e539a154ea5c4d4cb4e859601b246085 --
Sep 04 22:36:27 user upowerd[1148]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-2/5-2:1.2/0003:046D:C539.0006/0003:046D:407F.0008/power_supply/hidpp_battery_0
-- Boot e0e33d0eafa0448c929fe94849479d09 --
Sep 04 22:43:37 user upowerd[1151]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-2/5-2:1.2/0003:046D:C539.0006/0003:046D:407F.0008/power_supply/hidpp_battery_0
-- Boot 003933328f0e49d7ba1db41d4b0f9970 --
Sep 04 23:12:09 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-2/5-2:1.2/0003:046D:C539.0006/0003:046D:407F.0008/power_supply/hidpp_battery_0
-- Boot daf822ba41c74ecbbe4d6b1bc099355e --
Sep 04 23:37:52 user upowerd[1137]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-2/5-2:1.2/0003:046D:C539.0006/0003:046D:407F.0008/power_supply/hidpp_battery_0
-- Boot c290ec183daa48058f559379b4487119 --
Sep 04 23:47:18 user upowerd[1148]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-2/5-2:1.2/0003:046D:C539.0006/0003:046D:407F.0008/power_supply/hidpp_battery_0
-- Boot e1c431ee19d645b78a93964b02a4a4da --
Sep 04 23:53:30 user upowerd[1142]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-2/5-2:1.2/0003:046D:C539.0006/0003:046D:407F.0008/power_supply/hidpp_battery_0
-- Boot fe020bfd93f74df482dfaa8ef3dd2616 --
Sep 04 23:58:56 user upowerd[1143]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-2/5-2:1.2/0003:046D:C539.0006/0003:046D:407F.0008/power_supply/hidpp_battery_0
-- Boot 8cee97cc7de9473cabb3e8a64c3862b3 --
Sep 05 00:02:41 user upowerd[2907]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-2/5-2:1.2/0003:046D:C539.0006/0003:046D:407F.0008/power_supply/hidpp_battery_0
-- Boot 2677ba1e806f48aaa088716f2f26f5a8 --
Sep 05 00:14:28 user upowerd[1142]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-2/5-2:1.2/0003:046D:C539.0006/0003:046D:407F.0008/power_supply/hidpp_battery_0
-- Boot 2b7792d83c1a405382c54ca0ba251326 --
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb6
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-0:1.0
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-2
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-1
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb6/6-0:1.0
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-2/5-2:1.0
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-1/5-1:1.2
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-1/5-1:1.0
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-2/5-2:1.2
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-1/5-1:1.1
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-2/5-2:1.1
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-2/5-2:1.0/0003:046D:C539.0004
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-1/5-1:1.0/0003:046D:C545.0001
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-1/5-1:1.2/usbmisc/hiddev0
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-1/5-1:1.2/0003:046D:C545.0003
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-2/5-2:1.1/usbmisc/hiddev1
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-2/5-2:1.1/0003:046D:C539.0005
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-1/5-1:1.1/0003:046D:C545.0002
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-2/5-2:1.2/0003:046D:C539.0006
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-2/5-2:1.2/usbmisc/hiddev2
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-2/5-2:1.2/0003:046D:C539.0006/0003:046D:407F.0008
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-2/5-2:1.2/0003:046D:C539.0006/0003:046D:407F.0008/power_supply/hidpp_battery_0
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:07:00.3/usb3
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:07:00.1/usb2
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:07:00.1/usb1
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:07:00.3/usb4
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:07:00.3/usb3/3-0:1.0
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:07:00.1/usb2/2-0:1.0
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:07:00.1/usb1/1-0:1.0
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:07:00.3/usb3/3-2
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:07:00.1/usb1/1-6
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:07:00.1/usb1/1-5
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:07:00.3/usb4/4-0:1.0
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:07:00.3/usb4/4-2
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:07:00.3/usb3/3-2/3-2:1.0
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:07:00.1/usb1/1-6/1-6:1.1
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:07:00.1/usb1/1-5/1-5:1.0
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:07:00.3/usb4/4-2/4-2:1.0
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:07:00.1/usb1/1-6/1-6:1.0
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:07:00.1/usb1/1-5/1-5.3
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:07:00.1/usb1/1-5/1-5.3/1-5.3:1.0
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:07:00.1/usb1/1-5/1-5.3/1-5.3:1.2
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:07:00.1/usb1/1-5/1-5.3/1-5.3:1.2/0003:0B05:18F3.0007
Sep 05 00:40:57 user upowerd[1140]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:07:00.1/usb1/1-5/1-5.3/1-5.3:1.2/usbmisc/hiddev3
-- Boot 6d33db68a32a4b2bac9d325adf96f0b4 --
Sep 05 00:45:29 user upowerd[1138]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-2/5-2:1.2/0003:046D:C539.0006/0003:046D:407F.0008/power_supply/hidpp_battery_0
-- Boot 26812a412d9f499eaf8cac593efd6e97 --
Sep 05 01:57:13 user upowerd[1148]: Could not acquire inhibitor lock: GDBus.Error:org.freedesktop.DBus.Error.NoReply: Message recipient disconnected from message bus without replying
-- Boot 42d8cd24837a40b5aa8c9e1be4a2add8 --
-- Boot f7638126c079429f86a60baa1059f202 --
Sep 05 03:17:00 user upowerd[1135]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:07:00.3/usb3/3-4
-- Boot 2aac308645fa40bba6bcb46711c94631 --
Sep 05 03:19:23 user upowerd[1176]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:07:00.3/usb3/3-2/3-2.1
-- Boot 1134bb77e49040308b3df1ea67e09a5a --
Sep 05 03:20:14 user upowerd[1162]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:07:00.3/usb3/3-2/3-2.1
Sep 05 03:20:30 user upowerd[1162]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-2/5-2:1.2/0003:046D:C539.0006/0003:046D:407F.000B/power_supply/hidpp_battery_0
-- Boot acda6204a8514c1f978ca9471f561858 --
Sep 05 03:23:20 user upowerd[1171]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:07:00.3/usb3/3-2/3-2.1
Sep 05 03:23:24 user upowerd[1171]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-2/5-2:1.2/0003:046D:C539.0006/0003:046D:407F.0008/power_supply/hidpp_battery_0
-- Boot 800f3aea6be04b5183fd14ecde93762d --
Sep 05 03:24:02 user upowerd[1157]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:07:00.3/usb3/3-2/3-2.1
Sep 05 03:24:05 user upowerd[1157]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-2/5-2:1.2/0003:046D:C539.0006/0003:046D:407F.0008/power_supply/hidpp_battery_0
-- Boot 051c32a75bc0416ab2d413c58b9cd129 --
Sep 05 03:29:15 user upowerd[1169]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:07:00.3/usb3/3-2/3-2.1
Sep 05 03:29:18 user upowerd[1169]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-2/5-2:1.2/0003:046D:C539.0006/0003:046D:407F.0008/power_supply/hidpp_battery_0
-- Boot a508efbd79a841b7b29dfbdf822d25df --
Sep 05 03:40:13 user upowerd[1164]: treating change event as add on /sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:07:00.3/usb3/3-2/3-2.1
Sep 05 03:40:16 user upowerd[1164]: treating change event as add on /sys/devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb5/5-2/5-2:1.2/0003:046D:C539.0006/0003:046D:407F.0008/power_supply/hidpp_battery_0
  • free -m
              total        used        free      shared  buff/cache   available
Mem:          32075        1711       29190         107        1173       29855
Swap:          2047           0        2047
I've tried the changes below but I've had no success so far:
  • modifying /etc/default/grub with GRUB_CMDLINE_LINUX_DEFAULT="quiet splash noresume" and updating grub
  • modifying /etc/default/grub with GRUB_CMDLINE_LINUX_DEFAULT="nomodeset" and updating grub
  • checking that the nvidia proprietary drivers are installed (tried nvidia-driver-470 and nvidia-driver-460)
Edit: Unplugging all my USB devices (and HDMI EDID emulator) and plugging them back in again seems to have fixed all my issues. I will do some more testing to verify this. Thanks @CharlesGreen for the suggestion.
