I still can't seem to play movie DVDs on my Ubuntu 11.10 even after installing restricted extras and after trying this
This[a] is the error message that I get with movie player. VLC doesn't play the DVD either.
What gives
[a]Could not read DVD. This may be because the DVD is encrypted and a DVD decryption library is not installed.
dearN
  • 2,209
Open the Terminal under Applications > Accessories > Terminal and run the following commands:
sudo apt-get install libdvdnav4 libdvdread4 gstreamer0.10-plugins-bad gstreamer0.10-plugins-ugly
sudo /usr/share/doc/libdvdread4/install-css.sh
Reference:
Jorge Castro
  • 73,717
https://help.ubuntu.com/community/RestrictedFormats/PlayingDVDs
This link is a well written response the these kind of problems, including troubleshooting. Well worth a read Let us know if it helps Good Luck - Mal
Mal Noble
  • 51
From: http:// ubuntuforums.org/showthread.php?p=10711874
Originally Posted by uRock View Post https:// help.ubuntu.com/community/Medibuntu You need to install packages for decrypting the movies.
32bit
wget -c http://packages.medibuntu.org/pool/free/libd/libdvdcss/libdvdcss2_1.2.9-2medibuntu4_i386.deb
sudo dpkg -i libdvdcss2_1.2.9-2medibuntu4_i386.deb
64bit
wget -c http://packages.medibuntu.org/pool/free/libd/libdvdcss/libdvdcss2_1.2.9-2medibuntu4_amd64.deb
sudo dpkg -i libdvdcss2_1.2.9-2medibuntu4_amd64.deb
WIN.
devav2
  • 37,290
QUICKTIME. I stumbled to this post after searching the net for weeks. I tried everything, including "regionset". Today, after 4 weeks, I find my own solution, AFTER playing the dvds in Mac and Win7 and then browsing Filehippo for clues. QUICKTIME ! We need to install the quicktime lib and util, in addition to all the restricteds, libs, etc advised in the Ubuntu forum. Use Synaptic for this. This solved the problem why commercial dvd in China would not play. ps... if you get an error message about "blocks", your drive may be faulty.
rob grune
  • 1,161
