I am getting following error while trying to run sudo apt upgrade
Update:
If I try to remove libopenshot-audio7 via sudo apt remove libopenshot-audio7 following error shows.
(Whatever I am trying with
aptthis error shows whether remove, install or upgrade)
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
libopenshot20 : Depends: libopenshot-audio8 but it is not installed
python3-openshot : Depends: libopenshot-audio8 but it is not installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
So then I ran apt --fix-broken install after that following error is showing
(Reading database ... 284777 files and directories currently installed.)
Preparing to unpack .../libopenshot-audio8_0.2.1+dfsg2+139+202108251944~ubuntu20.04.1_amd64.deb ...
Unpacking libopenshot-audio8:amd64 (0.2.1+dfsg2+139+202108251944~ubuntu20.04.1) ...
dpkg: error processing archive /var/cache/apt/archives/libopenshot-audio8_0.2.1+dfsg2+139+202108251944~ubuntu20.04.1_amd64.deb (--unpack):
trying to overwrite '/usr/lib/x86_64-linux-gnu/libopenshot-audio.so.0.2.1', which is also in package libopenshot-audio7:amd64 0.2.0+dfsg2+139+202108251703~ubuntu20.04.1
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Distributor ID: Ubuntu
Description: Ubuntu 20.04.3 LTS
Release: 20.04
