I have recently purchased an RTSY pen tablet. It has a Windows driver but it doesn't have Ubuntu 20.04 drivers. Is there any way I could make it work on Ubuntu 20.04?
Model name is RTSY WP960
    That particular tablet is a rebranded “Digimend”, which can use the Wacom drivers. You’ll need to do a bit of tweaking, though:
sudo apt install xserver-xorg-input-wacom
sudo vi /etc/X11/xorg.conf.d/50-tablet.conf
vi, but you must be able to save the file as root.Section "InputClass"
  Identifier "Tablet"
  Driver "wacom"
  MatchDevicePath "/dev/input/event*"
  MatchUSBID "6161:4d15"
EndSection
After the system comes back up, you’ll be able to use exactly 1/2 of the tablet … because it’ll be in “Android Mode”. To use the entire drawing surface, hold the left and right buttons (not the middle) for 6 seconds. You will see a green light turn red. Once this is done, you can use the entire drawing surface.
