-3
On Ubuntu 18.04, I uninstalled python* which led to uninstallation of ubuntu-desktop and many other apps. I installed python3.8 and then ubuntu-desktop.
Now I can run command line on ctrl+alt+F3 but I cannot run it under graphical environment. I also tried
cp /etc/skel/.bashrc ~
Followed by logging again and it didn't help.
I also do not know the name of the graphical bash to try reinstalling.
What should I do?
Note: I also set python3.8 as alternative for python. Not sure that makes problem.
sudo update-alternatives --install /usr/bin/python python /usr/bin/python2.7 2
sudo update-alternatives --config python
And still having problem.
ar2015
  • 437
  • 19
Ubuntu relies heavily on python, so by removing python the tools that require it to function need to also be removed.
The tools also are built for a specific version of python, so if that version isn't available, you'll find they may no longer run (tools such as gnome-terminal requires the python it was built for; what came with your release; that was what it was tested to run with; if your system doesn't have that version - it may not run, or may not run correctly).
https://packages.ubuntu.com/bionic-updates/gnome-terminal
guiverc
  • 33,561
-4
it was fixed after
sudo update-alternatives --config python3
and pointing to python3.6 instead of python3.8.
By the way,
/usr/bin/gnome-terminal
has a head that starts with
#!/usr/bin/python3
Nothing to do with python2.
Still not clear what is the cause.
Update:
You do not need to change the default python version.
Just run
sudo nano '/usr/bin/gnome-terminal'
and change the header to:
#!/usr/bin/python3.6
Done.
Just ensure on the next software update, it is not overwritten.
ar2015
  • 437
  • 19
