During startup, if Ubuntu does not find itself within the UEFI Boot Order, it tries to automatically add another new entry before each other. but my UEFI setup has a setting called "Boot Order Lock", preventing any external changes to it.
Now on every boot, Ubuntu tries to add it's entry, prints "Reset System", then reboots and it starts from the beginning, since the new entry is not persisted due to the boot order locking.
This raises the question why it has to enforce a custom entry in the uefi boot order anyway during startup. I use an external SSD with a fully portable installation, which already has a custom standalone GRUB Bootloader installed, which also handles the Ubuntu startup. Therefore I simply don't want Ubuntu to insert or change anything in the boot order or prioritize itself over other boot options.
Now the system is stuck in a boot loop every time until I let it apply it's changes and insert that "ubuntu" entry as the primary boot option, over everything else. This is also not desired in cases, where it would be allowed to create an entry though, because as I said, this is a portable installation and it should never mess with the host system for any reason.
Is there any possibility to prevent this behavior entirely?
What I've found so far is:
- running
dpkg-reconfigure grub-x86_64-efiwhich is referred to often does not give any configuration options, the command just returns instantly - running
dpkg-reconfigure grub-pcjust asks for the desired Linux kernel parameters and nothing else - setting
grub2/update_nvramtofalseviadpkg-communicatealternatively doesn't change anything either
The system in question is a Lenovo Thinkpad P15v Gen 1, also with a full Ubuntu Setup. Other than usual in these posts I don't have any Dual-Boot setup present at the moment and Windows isn't installed anywhere. Nevertheless I might add other OSes in the future, therefore simply accepting Ubuntu booting for itself with it's own GRUB install is also not acceptable for me.
Any help or advice is greatly appreciated!
EDIT 2021-09-02:
Regarding the points raised in the comments, I would like to add to my previous information to make my concern a little clearer.
My external drive has it's own EFI partition right at the beginning of the disk. The disk layout currently consists roughly of:
- 1MiB free space (for compatibility with MBR)
- 256 MiB EFI partition, fat32, flags: boot, hidden, esp
- 512 MiB partition for standalone grub, fat32, flags: bios_grub
- 32 GiB swap partition for Ubuntu, linux-swap
- 256 GiB partition for Ubuntu, ext4
- a whole lot of free space for later use
I'm aware of the issue with Ubuntu always writing to the first EFI partition, regardless of what I choose as target during the installation. I already worked around that by installing it from a disk-less computer with only my external drive connected.
So this is less of a problem to me, I'm sorry if I didn't made this clear enough previously. My question is actually only about the UEFI boot order and preventing Ubuntu from adding a new entry for itself and it's own root partition on every boot (which I found it does).
As you may see from my partition layout before, there is a standalone boot partition for GRUB which contains the i386-pc version of it, with the x86_64-efi version installed properly inside the EFI partition. I initially set up the disk to boot my custom GRUB by default (which also has been overwritten meanwhile, but that's another issue I guess).
My goal is to boot only from this standalone version of GRUB, idependently from Ubuntu or any OS I might add in the future.
So this is actually two issues but with the same cause:
- It is meant to be portable, so I don't want it to leave footprints on any system I connect it to
- Ubuntu adding an entry in the UEFI boot order also entirely breaks my initial idea of using a standalone GRUB installation
What I want to achieve is booting into Ubuntu, without it searching, creating or reordering any boot list entry. Is that possible?
