I cant seem to find drives like E or D, in ubuntu, every folder or file get saved in the desktop itself. Please help
Asked
Active
Viewed 491 times
You can't.
Unix has the concept of a strictly hierarchical file system, with / as the root of the file system - and everything under that, even if it's a different physical drive or a network file system.
User's files are supposed to be in /home/username, or equivalent. The home directory contains everything personalized to a user, such as documents, configuration files, programs for that user and so forth.
Create directories in your home directory to organize things the way you prefer, but you should view /home/username as the only place to store files.
This incidentally makes backups easy; if you only care about user data, backup /home/ and ignore the rest of the system.
vidarlo
- 23,497
