My goal is to write a command to locate a file called MABLE on my server. Then I need to craft this command to report no permission errors, but print out every other error.
Currently, I'm using
find / -name MABLE
After that, I'm putting in
ls -d mable
This is not working. Any better way write the command?
zx485
  • 2,865
jjc
You can use "process substitution" to pass the results of the find command to grep, in order to filter out the messages including : Permission denied as in:
find / -name MABLE 2> >(grep -v ': Permission denied')
2> captures the error output and redirects that to the grep command, to which that output appears as a file (an "unnamed pipe").
vanadium
  • 97,564
