I have trouble finding the package for this software. I built and installed from the packages found here, but it's still not working properly with rvm and gem (log is located here). How would you suggest finding a package for this to work properly?
stanley@ubuntu:~/Github/webdev_class/ruby$ sudo apt-cache search ^openssl
[sudo] password for stanley:
openssl-blacklist - Blacklists for  OpenSSL RSA keys and tools
openssl-blacklist-extra - Non-default blacklists of OpenSSL RSA keys
libengine-pkcs11-openssl - OpenSSL engine for PKCS#11 modules
libxmlsec1-openssl - Openssl engine for the XML security library
openssl - Secure Socket Layer (SSL) binary and related cryptographic tools
Here is the printout after trying dpkg -l | grep openssl.
stanley@ubuntu:~/Github/webdev_class/ruby$ dpkg -l | grep openssl
ii  openssl                                1.0.0e-2ubuntu4.5                       Secure Socket Layer (SSL) binary and related cryptographic tools
ii  python-openssl                         0.12-1ubuntu1                           Python wrapper around the OpenSSL library
Use sudo apt-get install openssl, or use the software center to find it.
Install via the software center
When I look for packages, I generally use apt-cache search whatever.
For openssl, here's what I see on my system:
$ apt-cache search ^openssl
For gem dependencies, you would normally use something like :
sudo apt-get install ruby-full build-essential ruby-rvm yorick rubygems
However, apparently ruby-rvm is broken, so the ex(?)-maintainer's advice is to remove it completely, and install via the provided URL and bash script:
sudo apt-get --purge remove ruby-rvm
sudo rm -rf /usr/share/ruby-rvm /etc/rvmrc /etc/profile.d/rvm.sh
open new terminal and validate environment is clean from old rvm settings (should be no output):
env | grep rvm
if there was output, try to open new terminal, if it does not help - restart computer
install RVM:
curl -L get.rvm.io | bash -s stable
do not forget to read rvm requirements before installing rubies
belacqua
  • 23,540
OpenSSL is usually installed by default on Ubuntu. You can look up, why it is installed with:
aptitiude why package
For openssl this can be retraced to cups:
$ LANG=C aptitude why openssl
i   ssl-cert Depends openssl (>= 0.9.8g-9)
$ LANG=C aptitude why ssl-cert
i   cups Depends ssl-cert (>= 1.0.11)
(I used the LANG environment variable to get english output, not my local one).
I'm not sure but maybe rvm / gem do require the SSL development libraries, which are packaged into libssl-dev.
sudo apt-get install libssl-dev
This is usually the case when you compile something from source, what gem as I remember does, when resolving package dependencies.
Zanna
  • 72,312
mweinelt
  • 660
