Cpu's all stuck at 800Mhz
I type in watch -n1 "cat /proc/cpuinfo | grep MHz" (to see cpu's)
No matter what I do, I launch a large program and render an animation in Blender or use Octave to crunch numbers the CPU's don't go past 800Mhz
Computer
Summary
Computer
Processor   Intel(R) Core(TM) i7-4700MQ CPU @ 2.40GHz
Memory  16315MB (4407MB used)
Machine Type    Laptop
Operating System    Ubuntu 20.04.3 LTS
User Name   rt (rt)
Date/Time   Mon 30 Aug 2021 02:33:09 PM EDT
Display
Resolution  1920x1080 pixels
OpenGL Renderer Mesa DRI Intel(R) HD Graphics 4600 (HSW GT2)
X11 Vendor  The X.Org Foundation
Audio Devices
Audio Adapter   HDA-Intel - HDA Intel HDMI
Audio Adapter   HDA-Intel - HDA Intel PCH
Audio Adapter   USB-Audio - USB Audio Device
Input Devices
Power Button
Sleep Button
Lid Switch
Power Button
AT Translated Set 2 keyboard
USB Audio Device
ETPS/2 Elantech Touchpad
Logitech Anywhere MX
Video Bus
HDA Intel PCH Mic
HDA Intel PCH Front Headphone
HDA Intel HDMI HDMI/DP,pcm:3
HDA Intel HDMI HDMI/DP,pcm:7
HDA Intel HDMI HDMI/DP,pcm:8
HDA Intel HDMI HDMI/DP,pcm:9
HDA Intel HDMI HDMI/DP,pcm:10
Printers (CUPS)
OfficeJet_Pro_6978  Default
SCSI Disks
TSSTcorp CDDVDW SN-208DB
ATA INTEL SSDMCEAC12
ATA ST1000LM014-1EJ1
Operating System
Version
Kernel  Linux 5.4.0-81-generic (x86_64)
Version #91-Ubuntu SMP Thu Jul 15 19:09:17 UTC 2021
C Library   GNU C Library / (Ubuntu GLIBC 2.31-0ubuntu9.2) 2.31
Distribution    Ubuntu 20.04.3 LTS
Current Session
Computer Name   sys76
User Name   rt (rt)
Language    en_US.UTF-8 ()
Home Directory  /home/rt
Misc
Uptime  20 minutes
Load Average    0.83, 1.37, 1.62
Available entropy in /dev/random    3649 bits (healthy)
rt@sys76:/sys/devices/system/cpu/cpu0/cpufreq$ grep -r . scaling_min_freq:800000 scaling_available_governors:performance powersave scaling_governor:performance cpuinfo_max_freq:3400000 related_cpus:0 scaling_cur_freq:798264 scaling_setspeed:<unsupported> affected_cpus:0 scaling_max_freq:2400000 cpuinfo_transition_latency:0 scaling_driver:intel_pstate cpuinfo_min_freq:800000
rt@sys76:/sys/devices/system/cpu/cpufreq/policy0$ sensors coretemp-isa-0000 Adapter: ISA adapter Package id 0: +50.0°C (high = +84.0°C, crit = +100.0°C) Core 0: +50.0°C (high = +84.0°C, crit = +100.0°C) Core 1: +48.0°C (high = +84.0°C, crit = +100.0°C) Core 2: +45.0°C (high = +84.0°C, crit = +100.0°C) Core 3: +46.0°C (high = +84.0°C, crit = +100.0°C)
BAT0-acpi-0 Adapter: ACPI interface in0: 0.00 V
curr1: 0.00 A
acpitz-acpi-0 Adapter: ACPI interface temp1: +14.0°C (crit = +120.0°C)
As requested:
rt@sys76:~$ grep . /sys/devices/system/cpu/intel_pstate/*
/sys/devices/system/cpu/intel_pstate/max_perf_pct:100
/sys/devices/system/cpu/intel_pstate/min_perf_pct:23
/sys/devices/system/cpu/intel_pstate/no_turbo:1
/sys/devices/system/cpu/intel_pstate/num_pstates:27
/sys/devices/system/cpu/intel_pstate/status:active
/sys/devices/system/cpu/intel_pstate/turbo_pct:38
rt@sys76:~$ for file in /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor; do echo "powersave" > $file; done bash: /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor: Permission denied bash: /sys/devices/system/cpu/cpu1/cpufreq/scaling_governor: Permission denied bash: /sys/devices/system/cpu/cpu2/cpufreq/scaling_governor: Permission denied bash: /sys/devices/system/cpu/cpu3/cpufreq/scaling_governor: Permission denied bash: /sys/devices/system/cpu/cpu4/cpufreq/scaling_governor: Permission denied bash: /sys/devices/system/cpu/cpu5/cpufreq/scaling_governor: Permission denied bash: /sys/devices/system/cpu/cpu6/cpufreq/scaling_governor: Permission denied bash: /sys/devices/system/cpu/cpu7/cpufreq/scaling_governor: Permission denied
rt@sys76:~$ cpupower frequency-info --policy analyzing CPU 0: current policy: frequency should be within 800 MHz and 2.40 GHz. The governor "performance" may decide which speed to use within this range.
Rick T
  • 2,303
Here is how you can make your CPU go at max speed:
Make a file named cpumaxspeed.sh or any name that you like and enter in this code:
#!/bin/bash
#Getting and setting variables
echo Getting info....
CPUMIN=$(cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_min_freq) CPUMAX=$(cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq) CPUMAXGHZ=$(echo "scale=1; $CPUMAX / 1000000" | bc) CPUMINGHZ=$(echo "scale=1; $CPUMIN / 1000000" | bc)
#Display min and max CPU frequency in MHz echo CPU min frequency: $CPUMIN" MHz" / $CPUMINGHZ" GHz" echo CPU max frequency: $CPUMAX" MHz" / $CPUMAXGHZ" GHz"
#Setting CPU governor echo Setting governor to performance sudo cpufreq-set -r -g performance echo Set governor to performance
#Setting to max frequency echo Setting CPU frequency to be $CPUMAX" MHz" / $CPUMAXGHZ" GHz" sudo cpufreq-set -r -f $CPUMAXGHZ"GHz" echo Set CPU frequency to $CPUMAXGHZ"GHz"
done
To execute the file run this command:
sudo sh yourfilename.sh
Replace [yourfilename] with the name that you entered.
