I'm trying to install mpv player on fresh Ubuntu 20.04.3 installation with
sudo add-apt-repository ppa:mc3man/mpv-tests
sudo apt update && sudo apt install mpv
But response is as follows:
$ sudo apt install mpv
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: mpv : Depends: libaom0 (>= 1.0.0) but it is not installable Depends: libbluray2 (>= 1:0.2.2) but it is not installable Depends: libbs2b0 but it is not installable Depends: libdvdnav4 (>= 4.1.3) but it is not installable Depends: libfdk-aac1 (>= 0.1.4) but it is not installable Depends: libgme0 (>= 0.5.5) but it is not installable Depends: libgsm1 (>= 1.0.18) but it is not installable Depends: libmodplug1 (>= 1:0.8.8.5) but it is not installable Depends: libmysofa1 (>= 0.7~) but it is not installable Depends: librubberband2 (>= 1.8.2) but it is not installable Depends: libva-drm2 (>= 1.1.0) but it is not installable Depends: libva-wayland2 (>= 1.3.0) but it is not installable Depends: libva-x11-2 (>= 1.0.3) but it is not installable Depends: libva2 (>= 2.2.0) but it is not installable Depends: libx265-179 (>= 3.2) but it is not installable Depends: libxvidcore4 (>= 1.2.2) but it is not installable Recommends: i965-va-driver but it is not installable or libva-intel-vaapi-driver but it is not installable or va-driver but it is not installable Recommends: mesa-vdpau-drivers but it is not going to be installed or nvidia-vdpau-driver but it is not installable or nvidia-driver-binary or nvidia-current but it is not installable or vdpau-driver E: Unable to correct problems, you have held broken packages.
What is the possible source of problem could be here? I tried to fix broken dependencies with sudo apt-get -f install, but result is the same. Trying to install each package manually doesn't help as well:
$ sudo apt-get install libaom0
Package libaom0 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'libaom0' has no installation candidate
username
  • 403
