22
I'm trying to use ffmkv, which requires a version of ffmpeg that supports zscale.
Their README says this is the default under 18.04, but my version under 20.04 is 4.2.4-1ubuntu0.1, which doesn't seem to include zscale support.
If I run apt-get install ffmpeg, it says ffmpeg is already the newest version (7:4.2.4-1ubuntu0.1). but it's clear from ffmpeg.org that the current stable release is 4.3.2-0.
I tried adding ppa:jonathonf/ffmpeg-4 to pick up the latest, but that fails to update ("doesn't have a Release file").
What's the safest way to update it? Ideally, there's a PPA that will work, that my googling hasn't surfaced. Or, should I be downloading that ffmpeg_4.3.2-0+deb11u2ubuntu1_amd64.deb file and installing it with dpkg?
I'm always paranoid about side-channel installing anything, especially when it involves anything to do with Video. What's the best "won't break future system APT updates" way to install the current stable ffmpeg?
5 Answers5
16
There are other PPAs with newer ffmpeg. The most recent is FFmpeg 4 - media tool (Xenial & newer) from Rob Savoury. To add this PPA to your system use commands below:
sudo add-apt-repository ppa:savoury1/ffmpeg4
sudo apt-get update
sudo apt-get install ffmpeg
As the result you will get the version with --enable-libzimg compile flag and ffmkv will not complain about "HDR to SDR conversion or resolution changes".
Note: you can search PPAs by yourself using special local application named Y PPA Manager, .
N0rbert
  • 103,263
Simple solution
  1. Download an already compiled ffmpeg from johnvansickle.com. zscale support is included.
  2. Place the downloaded ffmpeg into your PATH by moving the downloaded ffmpeg into /usr/local/bin or ~/bin (re-login or run source ~/.profile if you move it into ~/bin).
This will not interfere with any system files or other packages. To uninstall simply delete the ffmpeg file.
I'm not a big fan of PPAs. They can be messy, are often overkill, and can cause problems by interfering with the package management system.
llogan
  • 12,348
There is a snap package for ffmpeg. The current version in the "stable" channel is 4.3.1 but does not list --enable-zimg in its build configuration as printed with -version, so it might not work. However, the "edge" channel of that snap package contains a version based on ffmpeg 4.4 with --enable-zimg. So installing would be as easy as
snap install ffmpeg --channel edge
Perhaps the best way to get a copy of FFmpeg and the zscale filter is to use, but slightly modify, the excellent FFmpeg trac compilation guide. This guide will not interfere with system libraries.
This can be accomplished in only two easy steps:
1. Install zimg:
When installing the long list of dependencies in the guide add the following to also install zimage:
   mkdir -p ~/ffmpeg_sources && \
   cd ~/ffmpeg_sources && \
   wget https://github.com/sekrit-twc/zimg/archive/refs/tags/release-3.0.2.tar.gz && \
   tar xvf release-3.0.2.tar.gz && \
   cd zimg-release-3.0.2 && \
   ./autogen.sh && \
   ./configure --prefix="$HOME/ffmpeg_build" --disable-shared && \
   make && \
   make install
This installs a local copy of zimg that FFmpeg will pick up when it is compiled.
2. Compile FFmpeg:
Follow the full FFmpeg trac guide and when you reach the section where FFmpeg is compiled simply add the following to the ./configure string:
   --enable-libzimg
And this will be enough to enable the zscale filter.
3. Testing, testing...
FFmpeg itself can be tested for presence of the zscale filter:
andrew@ithaca:~$ ffmpeg -filters 2> /dev/null |grep zscale
 ..C zscale            V->V       Apply resizing, colorspace and bit depth conversion.
andrew@ithaca:~$
I tested ffmkv itself with a big upscale in size:
andrew@ithaca:~$ ffmkv --preset 'Up to 4K, original audio, 4GB per hour VBR, HDR' input.mkv output.mkv
Audio is Stream Copy VBR, filesize will be greater than estimated.
Processing pass 1 of VBR video, remaining time is remaining time for pass 1 only.
Process will sit on 100% while ffmpeg closes out functions.
ffmpeg conversion of input.mkv started on 08/30/21 7:53:05 PM
input.mkv has 1248 frames, now converting
ffmpeg: 1253 of 1248 frames at 24 fps, progress: 100% and ETA: 0h 0m 0s
ffmpeg stopped on 08/30/21 7:54:06 PM
Processing pass 2 of VBR video, remaining time is total remaining time. Process will sit on 100% while ffmpeg closes out functions. ffmpeg conversion of input.mkv started on 08/30/21 7:54:06 PM input.mkv has 1248 frames, now converting ffmpeg: 1253 of 1248 frames at 23 fps, progress: 100% and ETA: 0h 0m 0s
ffmpeg stopped on 08/30/21 7:55:06 PM andrew@ithaca:~$
And all is well :)
andrew.46
  • 39,359
Adding external PPAs is very risky and often they might cause problems with your current installation.
If you are deploying your application and you need an specific version you can use this method.
First we will download the latest gpl static build from one of the official builders BtbN. Then we will extract the file in the /usr/local/ffmpeg and create Symbolic Links to the binaries into the /usr/bin directory.
This a manual installation process. You can create an script following all the steps mentioned here:
1. Remove previous package installed using apt
sudo apt remove --purge --auto-remove -y ffmpeg
2. Create a temporal directory and move to it
mkdir -vp ~/tmp
cd ~/tmp
3. Get the filename and the version
## Define repository name
REPO_NAME='BtbN/FFmpeg-Builds'
Define the URL of the latest release
LR_URL="https://api.github.com/repos/${REPO_NAME}/releases/latest"
Get the latest version
version=$(curl -s "${LR_URL}"
| grep -m 1 ffmpeg-n
| cut -d ':' -f2
| cut -d '-' -f2
| tr -d 'n'
| { read v; echo ${v::-2}; })
Get the filename
dl_filename=$(curl -s "${LR_URL}"
| grep "name.*linux64-gpl-${version}.tar.xz"
| cut -d ':' -f2
| { read n; echo ${n:1:-2}; })
dl_name="${dl_filename::-7}"
4. Download the file
## Download the latest tar.xz
curl -s "${LR_URL}" \
| grep "browser_download_url.*linux64-gpl-${version}.tar.xz" \
| cut -d ':' -f 2,3 \
| tr -d '"' \
| wget -qi - -O $dl_filename
5. Define package installation paths
pkg_path='/usr/local/ffmpeg'
pkg_lib_path='/usr/lib/ffmpeg'
6. Extract and install the downloaded version
sudo rm -rf $pkg_path && tar -xvf $dl_filename
sudo mv -v $dl_name $pkg_path
7. Add binary files to system binary and library directories
sudo ln -sv "${pkg_path}" "${pkg_lib_path}"
sudo ln -sv "${pkg_lib_path}/bin/ffmpeg" '/usr/bin/ffmpeg'
sudo ln -sv "${pkg_lib_path}/bin/ffplay" '/usr/bin/ffplay'
sudo ln -sv "${pkg_lib_path}/bin/ffprobe" '/usr/bin/ffprobe'
8. Test your new version.
ffmpeg -version | grep 'ffmpeg version'
Now you can create a script named ffmpeg-install-latest.sh:
#!/bin/bash
Define package name
PKG_NAME='ffmpeg'
Define system local path
LOCAL_PATH='/usr/local'
Define system library path
LIB_PATH='/usr/lib'
Define system binary path
BIN_PATH='/usr/bin'
Define user home dir
USER_HOME_DIR=$(getent passwd ${SUDO_USER:-$USER} | cut -d: -f6)
Define URL releases
RELEASES_URL="https://api.github.com/repos/${REPO_NAME}/releases"
Define URL of the latest release
LR_URL="${RELEASES_URL}/latest"
Define temporal directory
TMP_DIR='tmp'
Move to the temporal directory
tmp_path="${USER_HOME_DIR}/${TMP_DIR}" mkdir -vp $tmp_path cd $tmp_path
Get the latest version and build
full_version=$(curl -s "${LR_URL}"
| grep -m 1 ffmpeg-n
| cut -d ':' -f2
| cut -d '-' -f2
| tr -d 'n')
version="${full_version::-2}" build="${full_version:4:1}"
echo 'Latest version: '$full_version
Get the filename
| cut -d ':' -f2
echo 'File to download: '$dl_filename
Download the latest
Base on: echo $(curl -s "${LR_URL}"" | grep "browser_download_url.ffmpeg-n4.4.1.linux64-gpl-4.4.tar.xz" | cut -d ':' -f 2,3 | tr -d '"')
curl -s "${LR_URL}"
| cut -d ':' -f 2,3
| tr -d '"'
status="$(dpkg-query -W --showformat='${db:Status-Status}' ${PKG_NAME} 2>&1)" if [ $? = 0 ] || [ "${status}" = installed ]; then sudo apt remove --purge --auto-remove -y "${PKG_NAME}" fi
pkg_path="${LOCAL_PATH}/${PKG_NAME}" pkg_lib_path="${LIB_PATH}/${PKG_NAME}"
sudo rm -rf $pkg_path && tar -xvf $dl_filename sudo mv -v $dl_name $pkg_path
sudo ln -sv "${pkg_path}" "${pkg_lib_path}" sudo ln -sv "${pkg_lib_path}/bin/ffmpeg" "${BIN_PATH}/ffmpeg" sudo ln -sv "${pkg_lib_path}/bin/ffplay" "${BIN_PATH}/ffplay" sudo ln -sv "${pkg_lib_path}/bin/ffprobe" "${BIN_PATH}/ffprobe"
Teocci
  • 5,025
