I'm trying to set up Chrome Remote Desktop on Ubuntu 21.04. It downloads a .deb file which I then try to install via Terminal.
It starts installing but finally I get this error:
libdvd-pkg: `apt-get check` failed, you may have broken packages. Aborting...
I get this error quite a lot when trying to install apps but I don't know how to fix the problem. Does anyone have suggestions to fix broken packages?
I ran sudo apt update and got this result:
Hit:1 http://au.archive.ubuntu.com/ubuntu hirsute InRelease
Ign:2 http://dl.google.com/linux/chrome-remote-desktop/deb stable InRelease
Hit:3 http://au.archive.ubuntu.com/ubuntu hirsute-updates InRelease
Hit:4 http://security.ubuntu.com/ubuntu hirsute-security InRelease
Hit:5 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:6 http://archive.canonical.com/ubuntu focal InRelease
Hit:7 http://dl.google.com/linux/chrome-remote-desktop/deb stable Release
Ign:8 http://ppa.launchpad.net/clipgrab-team/ppa/ubuntu hirsute InRelease
Ign:10 https://www.mediahuman.com/packages/ubuntu hirsute InRelease
Err:11 http://ppa.launchpad.net/clipgrab-team/ppa/ubuntu hirsute Release
404 Not Found [IP: 91.189.95.85 80]
Err:12 https://www.mediahuman.com/packages/ubuntu hirsute Release
404 Not Found [IP: 169.60.33.180 443]
Get:13 http://au.archive.ubuntu.com/ubuntu focal-updates InRelease [114 kB]
Get:14 http://au.archive.ubuntu.com/ubuntu hirsute-backports InRelease [101 kB]
Get:15 http://au.archive.ubuntu.com/ubuntu hirsute-backports/universe amd64 DEP-11 Metadata [9,268 B]
Reading package lists... Done
E: The repository 'http://ppa.launchpad.net/clipgrab-team/ppa/ubuntu hirsute Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: The repository 'https://www.mediahuman.com/packages/ubuntu hirsute Release' does not have a Release file.
Then I ran sudo apt upgrade and got this:
Building dependency tree... Done
Calculating upgrade... Done
The following packages will be upgraded:
google-chrome-stable
1 to upgrade, 0 to newly install, 0 to remove and 0 not to upgrade.
Need to get 80.2 MB of archives.
After this operation, 19.3 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://dl.google.com/linux/chrome/deb stable/main amd64 google-chrome-stable amd64 92.0.4515.159-1 [80.2 MB]
Fetched 80.2 MB in 35s (2,318 kB/s)
(Reading database ... 239339 files and directories currently installed.)
Preparing to unpack .../google-chrome-stable_92.0.4515.159-1_amd64.deb ...
Unpacking google-chrome-stable (92.0.4515.159-1) over (85.0.4183.121-1) ...
Setting up google-chrome-stable (92.0.4515.159-1) ...
Processing triggers for gnome-menus (3.36.0-1ubuntu1) ...
Processing triggers for man-db (2.9.4-2) ...
Processing triggers for mailcap (3.68ubuntu1) ...
Processing triggers for desktop-file-utils (0.26-1ubuntu1) ...
libdvd-pkg: Checking orig.tar integrity...
/usr/src/libdvd-pkg/libdvdcss_1.4.2.orig.tar.bz2: OK
Notice the last line which is what I often get when trying to load software.
I ran sudo dpkg-reconfigure libdvd-pkg anyway and got this:
libdvd-pkg: Unpacking and configuring...
libdvd-pkg: Building the package... (it may take a while)
libdvd-pkg: Build log will be saved to /usr/src/libdvd-pkg/libdvdcss2_1.4.2-1~local_amd64.build
Current: =ep
Bounding set =cap_chown,cap_dac_override,cap_fowner,cap_wake_alarm,cap_block_suspend,cap_audit_read,cap_perfmon,cap_bpf,cap_checkpoint_restore
Ambient set =
Current IAB: !cap_dac_read_search,!cap_fsetid,!cap_kill,!cap_setgid,!cap_setuid,!cap_setpcap,!cap_linux_immutable,!cap_net_bind_service,!cap_net_broadcast,!cap_net_admin,!cap_net_raw,!cap_ipc_lock,!cap_ipc_owner,!cap_sys_module,!cap_sys_rawio,!cap_sys_chroot,!cap_sys_ptrace,!cap_sys_pacct,!cap_sys_admin,!cap_sys_boot,!cap_sys_nice,!cap_sys_resource,!cap_sys_time,!cap_sys_tty_config,!cap_mknod,!cap_lease,!cap_audit_write,!cap_audit_control,!cap_setfcap,!cap_mac_override,!cap_mac_admin,!cap_syslog
Securebits: 024/0x14/5'b10100
secure-noroot: no (unlocked)
secure-no-suid-fixup: yes (unlocked)
secure-keep-caps: yes (unlocked)
secure-no-ambient-raise: no (unlocked)
uid=0(root) euid=0(root)
gid=0(root)
groups=0(root)
Guessed mode: UNCERTAIN (0)
libdvd-pkg: Installing...
Selecting previously unselected package libdvdcss-dev:amd64.
(Reading database ... 239337 files and directories currently installed.)
Preparing to unpack .../libdvdcss-dev_1.4.2-1~local_amd64.deb ...
Unpacking libdvdcss-dev:amd64 (1.4.2-1~local) ...
Selecting previously unselected package libdvdcss2:amd64.
Preparing to unpack .../libdvdcss2_1.4.2-1~local_amd64.deb ...
Unpacking libdvdcss2:amd64 (1.4.2-1~local) ...
Setting up libdvdcss2:amd64 (1.4.2-1~local) ...
Setting up libdvdcss-dev:amd64 (1.4.2-1~local) ...
Processing triggers for libc-bin (2.33-0ubuntu5) ...
Although I've been using Ubuntu for some time, the above details mean little to me as I'm far from an expert. Is there something else I can do now?
