When I try to install mariadb-server on Ubuntu 21.04 using:
sudo apt install mariadb-server
It shows this error:
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: mariadb-server : Depends: mariadb-server-10.3 (>= 1:10.3.31-0ubuntu0.20.04.1) but it is not going to be installed E: Unable to correct problems, you have held broken packages.
Ollie
  • 3,372
pvdboom
MariaDB has their own repository with support for 21.04... See the link below.
https://mariadb.com/kb/en/installing-mariadb-deb-files/
Roxana
  • 76
You should have a package available in usual repos.
The error message you are getting can stem from various reasons. Things you could try to either overcome the problem or identify the causes are:
  1. sudo apt update prior to installing.
  2. sudo apt autoremove prior to update.
  3. List held packages with dpkg --get-selections | grep hold (or dpkg --get-selections | grep "\<hold$" as per this).
  4. sudo apt-get -f install mariadb-server` to force installation.
Sources
  1. Unable to correct problems, you have held broken packages
