My ProtonVPN connection keeps breaking. I'm using Ubuntu 18.04. ProtonVPN informs me that the issue is with Ubuntu, they won't help me fix it, and that I should post here. This is a cross-post of this Unix SE question.
Right now, in the broken state, the two ProtonVPN device profiles proton0 and ipv6leakintrf0 are listed as "unmanaged" and "disconnected", respectively, by nmcli:
$ nmcli d
DEVICE          TYPE      STATE         CONNECTION
wlp3s0          wifi      connected     WifiAP
ipv6leakintrf0  dummy     disconnected  --
enp2s0          ethernet  unavailable   --
lo              loopback  unmanaged     --
proton0         tun       unmanaged     --
ProtonVPN support has not been able to resolve the issue after working on it for nearly two months, but they did inform me they don't support unmanaged connections. So, I'm struggling on my own to make both proton0 and ipv6leakintrf0 be "managed".
From what I can piece together from the NetworkManager configuration documentation, NetworkManager configures devices from the following sources, in order:
  1. /usr/lib/NetworkManager/conf.d/
  2. /run/NetworkManager/conf.d/
  3. /etc/NetworkManager/conf.d/
  4. /etc/NetworkManager.conf
  5. /var/lib/NetworkManager/NetworkManager-intern.conf
Within the three directories, files are parsed in their listed order. On my system, the file /usr/lib/NetworkManager/conf.d/10-globally-managed-devices.conf exists and contains the following directive:
[keyfile]
unmanaged-devices=*,except:type:wifi,except:type:wwan
This appears to set all non-wifi and non-wan network devices to "unmanaged", which would explain why proton0 and probably ipv6leakintrf0 are unmanaged. However, given how poorly-designed the NetworkManager UX is, there's no way for me to be certain that subsequent configuration I don't understand isn't overriding this directive.
I searched the above configuration list for another unmanaged-devices directive and found none, so I can only assume the one in 10-globally-managed-devices.conf is the only one. In that case, it seems like I could correct the problem and make proton0 a managed device by creating a file /usr/lib/NetworkManager/conf.d/80-proton-vpn.conf with the following contents:
[device]
match-device=interface-name:proton0
managed=true
[device] match-device=interface-name:ipv6leakintrf0 managed=true
where I've pieced the syntax together as best I can from the poor documentation linked above. I restarted network-manager. ProtonVPN worked for several days before breaking again, giving the $ nmcli d output shown above that indicates proton0 (and probably ipv6leakintrf0) are still unmanaged, despite my best efforts at changing the config.
This AskUbuntu answer indicates that the listing of a device in /etc/network/interfaces will cause it to be unmanaged by NetworkManager. In my case that does not apply, the only contents of that file are
$ cat /etc/network/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
auto lo
iface lo inet loopback
I've also tried explicitly excepting the ProtonVPN devices in 10-globally-managed-devices.conf as suggested by a comment on the Unix SE post I linked above:
[keyfile]
unmanaged-devices=*,except:type:wifi,except:type:wwan,except:interface-name:proton*,except:interface-name:ipv6leakintrf*
After restarting network-manager, this config made no change in the problem.
What else do I have to do to make these device profiles be managed by NetworkManager?
Edit
For the question "How do I set a network device to be managed?", the answer to start with is:
"Run the command
$ nmcli device set <name> managed yes
where <name> is the relevant entry under the DEVICE column of the output of $ nmcli d."
I've been working on this problem for such a soul-drainingly long time that I forgot to include the results of doing this. Here they are:
When I run
$ nmcli device set proton0 managed yes
it does not affect 'proton0' in any way. The output of $ nmcli d continues to show 'proton0' as "disconnected" (because I can't connect), and the output of $ nmcli device show continues to show 'proton0' as having GENERAL.STATE: 10 (unmanaged).
'ipv6leakintrf0' has appeared and disappeared throughout the troubleshooting process. I don't know why, but ProtonVPN support didn't find it noteworthy, so I assume it's expected. When it exists, running
$ nmcli device set ipv6leakintrf0 managed yes
has no effect. The output of $ nmcli d continues to show it as "unmanaged". When it doesn't exist, running the $ nmcli device set command returns the error Error: Device 'ipv6leakintrf0' not found., which seems normal. It currently does not exist.
extra info
Here is the 'proton0' portion of the output of $ nmcli device show:
GENERAL.DEVICE:                         proton0
GENERAL.TYPE:                           tun
GENERAL.HWADDR:                         (unknown)
GENERAL.MTU:                            1500
GENERAL.MTU:                            1500
GENERAL.STATE:                          20 (unavailable)
GENERAL.CONNECTION:                     --
GENERAL.CON-PATH:                       --
WIRED-PROPERTIES.CARRIER:               off
This is what I have
$ cat /usr/lib/NetworkManager/conf.d/10-globally-managed-devices.conf
[keyfile]
unmanaged-devices=*,except:type:wifi,except:type:gsm,except:type:cdma
I have two devices which I am certain they correspond to ProtonVPN, since their modification date are affected by connecting/disconnecting
$ cat /run/NetworkManager/devices/19
[device]
managed=true
connection-uuid=...
nm-owned=false
$ cat /run/NetworkManager/devices/18
[device]
managed=true
perm-hw-addr-fake=...
connection-uuid=...
nm-owned=true
route-metric-default-effective=550
When I am disconnected, they look like this
[device]
nm-owned=false
[device]
managed=true
nm-owned=true
I guess they are not meant to be manually modified, but this may help.
Please post the output of
$ nmcli device show
Also, forcing managed connections as shown in https://developer-old.gnome.org/NetworkManager/unstable/NetworkManager.html may help
Udev Properties
udev(7) device manager is used for the network device discovery. The following property influences how NetworkManager manages the devices:
NM_UNMANAGED If set to "1" or "true", the device is configured as unmanaged by NetworkManager. Note that the user still can explicitly overrule this configuration via means like nmcli device set "$DEVICE" managed yes or "device*.managed=1" in NetworkManager.conf.
So please post the result of using
as shown e.g. here.
And check with ls -al /etc/udev/rules.d/ if there is any udev rule that may tell Network Manager to stop controlling an interface
