I'm currently using 11.10.
I have a downloaded copy of 12.04 on CD.
Question: Is it the same if I hit the UPGRADE button on the update manager, or install 12.04 through the CD? Will I lose my work/settings/installed apps (LAMP, Lazarus, etc) by either method? I know if I boot from the CD and install, I'll most certainly lose everything... But my question is will this happen even if I run the CD while on Ubuntu?
Thanks!
Jorge Castro
  • 73,717
itsols
  • 1,200
You should understand that the Ubuntu Live-CDs (which most people download) do NOT contain the .deb packages that are used for an upgrade; instead, they contain the entire filesystem in compressed form, so that it can be used both for the LiveCD, and to perform a new installation (the filesystem is simply copied to the hard disk in that case).
If you have decent internet access, it is HIGHLY recommended to go the upgrade route. If you don't, maybe you can get your hands on the alternate CD? That does have the regular deb packages/repository, and you could conceivably use apt-cdrom to add it to your /etc/apt/sources.list as a local repository and use it for the upgrade.
ish
  • 141,990
