There is a problem with my display ouput.
The Asus ZenScreen monitor cannot detect a signal after switching off and on again. I will have to hibernate the machine before the display can work again.
Apparently, the system is unable to detect the xrandr connection type for my display:
xrandr
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 1920 x 1080, current 1920 x 1080, maximum 1920 x 1080
default connected primary 1920x1080+0+0 0mm x 0mm
1920x1080 77.00*
1920x1080_60.00 (0x55a) 173.000MHz -HSync +VSync
h: width 1920 start 2048 end 2248 total 2576 skew 0 clock 67.16KHz
v: height 1080 start 1083 end 1088 total 1120 clock 59.96Hz
possibly due to a lack of driver for my graphics card:
inxi -G
Graphics:
Device-1: Intel UHD Graphics driver: N/A
Display: x11 server: X.Org 1.20.11 driver: fbdev
unloaded: modesetting,vesa resolution: 1920x1080~77Hz
OpenGL: renderer: llvmpipe (LLVM 12.0.0 256 bits)
v: 4.5 Mesa 21.0.3
It says here that a kernel upgrade is needed,
intel_gpu_top
Failed to detect engines! (No such file or directory)
(Kernel 4.16 or newer is required for i915 PMU support.)
But my kernel version is clearly newer than the 4.16 requirement.
uname -r
5.11.0-27-generic
Assuming the driver is already installed with the kernel, though I can select intel as my driver,
prime-select query
intel
it is apparent the Intel UHD Graphics card cannot detect any compatible driver in the kernel. (No Kernel driver in use in the output below.)
lspci -k
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics (rev 02)
DeviceName: GPU
Subsystem: Intel Corporation UHD Graphics
Kernel modules: i915
Can someone diagnose what's the issue over here?
The xrandr command had been working properly with the same setup before.
