I am having a problem accessing two older usb (2.x) flash drives (a SanDisk 128MB drive and a Verbatim 2GB Store 'n' Go drive) using Kubuntu 20.04.02 LTS kept fully updated through Discover. I have inserted each flash drive into the same USB port then issued the following commands for each drive in turn.
df -h
sudo parted -ls
sudo lsblk -f
sudo lsblk -m
ls -ld /media
ls -l /media
ls -l /media/$USER
The results are shown below.
For the 128 MB drive we have :-
kub@kub-SATELLITE-L870-18V:~$ df -h
Filesystem Size Used Avail Use% Mounted on
udev 3.8G 0 3.8G 0% /dev
tmpfs 785M 1.5M 783M 1% /run
/dev/sda9 152G 3.0G 141G 3% /
/dev/sda10 152G 21G 123G 15% /usr
tmpfs 3.9G 152K 3.9G 1% /dev/shm
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 3.9G 0 3.9G 0% /sys/fs/cgroup
/dev/sda1 446M 309M 103M 76% /boot
/dev/sda6 169M 332K 155M 1% /tmp
/dev/sda7 14G 2.6G 11G 20% /var
/dev/sda5 137G 46G 85G 35% /home
tmpfs 785M 12K 785M 1% /run/user/1000
kub@kub-SATELLITE-L870-18V:~$ sudo parted -ls
[sudo] password for kub:
Model: ATA ST9500325AS (scsi)
Disk /dev/sda: 500GB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 500MB 499MB primary ext4 boot
2 501MB 500GB 500GB extended
6 501MB 700MB 199MB logical ext4
7 701MB 15.7GB 15.0GB logical ext4
8 15.7GB 17.7GB 2047MB logical linux-swap(v1)
9 17.7GB 184GB 166GB logical ext4
10 184GB 350GB 166GB logical ext4
5 350GB 500GB 150GB logical ext4
kub@kub-SATELLITE-L870-18V:~$ sudo lsblk -f
NAME FSTYPE LABEL UUID FSAVAIL FSUSE% MOUNTPOINT
sda
├─sda1 ext4 /boot d12eeea7-3bf7-4bab-874b-307afc53005d 102.9M 69% /boot
├─sda2
├─sda5 ext4 /home 05fc8b81-a330-4c74-91ed-77f37aa16a9c 84.5G 33% /home
├─sda6 ext4 /tmp f7cd437f-0a1f-4340-bf0f-4b96844b9686 154.4M 0% /tmp
├─sda7 ext4 /var da489418-829c-4450-84f4-6c878b20f6f2 10.4G 19% /var
├─sda8 swap swap 7cc86fae-5fec-413c-90df-ca2f9f95491c [SWAP]
├─sda9 ext4 / 56d7e93d-4217-41c3-82f3-f457af294496 140.6G 2% /
└─sda10 ext4 /usr fe345b5a-b2a0-47e3-a4b1-89d25492fb3d 122.6G 14% /usr
sr0
kub@kub-SATELLITE-L870-18V:~$ sudo lsblk -m
NAME SIZE OWNER GROUP MODE
sda 465.8G root disk brw-rw----
├─sda1 476M root disk brw-rw----
├─sda2 1K root disk brw-rw----
├─sda5 139.8G root disk brw-rw----
├─sda6 190M root disk brw-rw----
├─sda7 14G root disk brw-rw----
├─sda8 1.9G root disk brw-rw----
├─sda9 154.7G root disk brw-rw----
└─sda10 154.7G root disk brw-rw----
sr0 1024M root cdrom brw-rw----
kub@kub-SATELLITE-L870-18V:~$ ls -ld /media
drwxr-xr-x 11 root root 4096 Apr 17 12:32 /media
kub@kub-SATELLITE-L870-18V:~$ ls -l /media
total 36
drwxr-x---+ 2 kub kub 4096 Aug 19 09:56 kub
lrwxrwxrwx 1 root root 4 Apr 17 12:32 usb -> usb0
drwxr-xr-x 2 root root 4096 Apr 17 12:32 usb0
drwxr-xr-x 2 root root 4096 Apr 17 12:32 usb1
drwxr-xr-x 2 root root 4096 Apr 17 12:32 usb2
drwxr-xr-x 2 root root 4096 Apr 17 12:32 usb3
drwxr-xr-x 2 root root 4096 Apr 17 12:32 usb4
drwxr-xr-x 2 root root 4096 Apr 17 12:32 usb5
drwxr-xr-x 2 root root 4096 Apr 17 12:32 usb6
drwxr-xr-x 2 root root 4096 Apr 17 12:32 usb7
kub@kub-SATELLITE-L870-18V:~$ ls -l /media/$USER
total 0
For the 2 GB drive we have :-
Disk Flags:
Error: /dev/sdc: unrecognised disk label
Model: Verbatim Store 'n' Go (scsi)
Disk /dev/sdc: 1011MB
Partition Table: unknown
Disk Flags:
sda
├─sda2
sdc
sr0
sdc 964M root disk brw-rw----
total 36
total 0
Neither device automounts or shows up in Dolphin.
I have been to the websites for both Ours Technology Inc and Trek2000 (previously known as Trek Technology PTE LTD, according to Wikipedia) and found no support for either of these old devices.
ASIDE: i have tried two other USB flash drives in the same USB port and both of those devices do automount and show up in Dolphin.
Is there some way that I can once again access these devices ?
Best regards,
Stuart
