I know I'm not the only one running into this issue. I have been following a lot of instructions on several posts here and elsewhere. I will sum up what I have tried to fix this.
First my system: Legion 5 Pro with a Nvidia RTX3070 on Ubuntu 20.04.2 LTS.
It was a real chore to get ubuntu running properly on this machine, mainly because of nvidia drivers. But it's alomost working now, except for the screen brightness control, which is quite an issue because this screen is way to bright at 100%.
What I tried:
sudo vim /usr/share/X11/xorg.conf.d/10-nvidia-conf
Added this: Option "RegistryDwords" "EnableBrightnessControl=1"
So now it looks like this:
Section "OutputClass"
    Identifier "nvidia"
    MatchDriver "nvidia-drm"
    Driver "nvidia"
    Option "AllowEmptyInitialConfiguration"
    ModulePath "/usr/lib/x86_64-linux-gnu/nvidia/xorg"
EndSection
Also added Option "RegistryDwords" "EnableBrightnessControl=1" and Option "Backlight" "nvidia_0" to the Device section of /etc/X11/xorg.conf
So it looks like this:
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
    BoardName      "NVIDIA GeForce RTX 3070 Laptop GPU"
EndSection
I also updated:
sudo nano /etc/initramfs-tools/modules
And added
nvidia
nvidia-drm
nvidia-modeset
Then updated initramfs like this
sudo update-initramfs -u
I also updated the grub configuration like this:
sudo vim /etc/default/grub
And added acpi_backlight=vendor to this variable: GRUB_CMDLINE_LINUX_DEFAULT so now it looks like this:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_backlight=vendor"
And updated grup: sudo update-grub
None of those things make any difference. The nvidia driver itself seems to work properly, but the brightness controls do not work. I do see the ui on screen with the bar changing, but the screen does not do anything. I also have the slider available in power control, but sliding it does not make any change.
I'm at a loss here, hopefully someone has another idea on how to fix this.
Well... after a day of searching I figured I might just as well try to downgrade my drivers. From 470.x to 460.x. Now it works! It seems some bug introduced in the newer drivers. Hope nvidia makes a fix soon enough.
Are you in safe mode? in boot menu press e to edit and if you see this nomodeset in a line remove the nomodeset word and press control + x or f10.
Ashiq Tasdid
  • 73
If your BIOS setting is set to dynamic / hybrid mode
Edit grub’s config:
Change the line:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
To:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash video.use_native_backlight=1"
Then run:
sudo update-grub
And restart the laptop.
(source: VV0JC13CH)
If your BIOS setting is set to discrete mode (with nvidia driver)
Edit grub’s config:
Change the line:
To:
GRUB_CMDLINE_LINUX="nvidia-drm.modeset=1 acpi_backlight=native nvidia.NVreg_RegistryDwords=EnableBrightnessControl=1"
Then run:
sudo update-grub
(source: BertRAMAerts here)
Pierre
  • 204
