I have written a script that downloads and installs anaconda3, and some other dependencies, and then it installs a couple of python modules using pip3.
The issue is that my source ~/.bashrc doesn't seem to work, and thus pip3's are not recognized. If I use exec bash, the remaining instructions after this command are not executed.
What should I do?
This is my script by the way :
#!/bin/bash
Bash script for setting up a PX4 development environment on Ubuntu LTS (16.04 and above).
It can be used for installing simulators (only) or for installing the preconditions for Snapdragon Flight or Raspberry Pi.
Installs:
- Common dependencies and tools for all targets (including: Ninja build system, latest versions of cmake, git, anaconda3, pyulog)
- jMAVSim simulator dependencies
- PX4/Firmware source (to ~/src/Firmware/)
Preventing sudo timeout https://serverfault.com/a/833888
trap "exit" INT TERM; trap "kill 0" EXIT; sudo -v || exit $?; sleep 1; while true; do sleep 60; sudo -nv; done 2>/dev/null &
Ubuntu Config
echo "Remove modemmanager"
sudo apt-get remove modemmanager -y
echo "Add user to dialout group for serial port access (reboot required)"
sudo usermod -a -G dialout $USER
Update CMake and Git
Installing latest version of cmake (ref https://askubuntu.com/questions/355565/#865294 )
echo "Installing latest version of CMake"
sudo apt update &&
sudo apt install -y software-properties-common lsb-release &&
sudo apt clean all
wget -O - https://apt.kitware.com/keys/kitware-archive-latest.asc 2>/dev/null | gpg --dearmor - | sudo tee /etc/apt/trusted.gpg.d/kitware.gpg >/dev/null
sudo apt-add-repository "deb https://apt.kitware.com/ubuntu/ $(lsb_release -cs) main"
sudo apt update
sudo apt install kitware-archive-keyring
sudo rm /etc/apt/trusted.gpg.d/kitware.gpg
sudo apt update
sudo apt install cmake
Installing the latest version of git
echo "Installing the latest version of git"
sudo add-apt-repository -y ppa:git-core/ppa
sudo apt-get update
sudo apt-get install git -y
Install anaconda3
type conda >/dev/null 2>&1 || { echo >&2 "Installing anaconda3 (python 3.8.8)"; wget https://repo.anaconda.com/archive/Anaconda3-2021.05-Linux-x86_64.sh; bash ./Anaconda3-2021.05-Linux-x86_64.sh;}
source ~/.bashrc
. ~/.bashrc
Common dependencies
echo "Installing common dependencies"
sudo apt-get update -y
sudo apt-get install git zip cmake build-essential genromfs ninja-build exiftool astyle -y
make sure xxd is installed, dedicated xxd package since Ubuntu 18.04 but was squashed into vim-common before
which xxd || sudo apt install xxd -y || sudo apt-get install vim-common --no-install-recommends -y
Required python packages
pip3 install argparse empy toml numpy
pip3 install pandas jinja2 pyserial pyyaml
pip3 install pyulog
echo "Installing jMAVSim simulator dependencies"
sudo apt-get install ant openjdk-8-jdk openjdk-8-jre -y
