I have a desktop computer with only Ubuntu 20.04 installed. I have a few HDDs inside for storage that were used in a windows system before and are showing small windows partitions that I'm not able to remove with the Disks app, there is an error every time I try. Does someone knows how to wipe completely these drives and have them like factory new? I really don't want to see these little partitions anymore. thanks in advance for your help! :)
Asked
Active
Viewed 45 times
Gparted should be able to do this. It's pre-installed on a live USB but not the normal installation, but you can download it from Ubuntu Software. You should be able to see / resize / delete any partition that isn't currently mounted using Gparted. If you want to delete all partitions except for the one you are using (ie the live Ubuntu partition) then there is no risk ... obviously if there is anything on any of the partitions you might ever want, be very careful about which ones you select to delete.
Will
- 2,483
- 5
- 20
- 34
