I'm trying to get an Epson X19 scanner working. First, I downloaded their driver package for 20.04 LTS. This broke because apt-get update returned errors because of a google earth repository gone missing and an eoan archive. I eliminated these from the source list. The install seemed to work.
I tried this:
# apt-get install sane sane-utils libsane xsane
Reading package lists... Done
Building dependency tree
libsane is already the newest version (1.0.29-0ubuntu5.2).
libsane set to manually installed.
sane-utils is already the newest version (1.0.29-0ubuntu5.2).
sane : Depends: libgimp2.0 (>= 2.4.0) but it is not going to be installed
xsane : Depends: libgimp2.0 (>= 2.4.0) but it is not going to be installed
As suggested in answers to similar questions, I ran the standard apt commands to find and fix dependencies. None were found to fix. I uninstalled the Epson driver package and repeated the experiment with the same results.
These came up empty:
# dpkg -l | grep ^..r
# apt-get check
# dpkg-query -W -f='${db:Status-Abbrev} ${binary:Package}\n' | grep -E ^.[^nci]
I tried uninstalling Gimp, which was installed by SNAP. That worked. Now trying to reinstall through apt-get t hits the same error.
Since various utilities have been unable to identify a currently broken package, I have to ask: Is there a flag set in some file under /etc that marks me forever for the sin of having held a broken package?
