I am using Ubuntu 18.04.4 LTS, and I am attempting to install libgpgme-dev. Here is the command and output.
$ sudo apt install libgpgme-dev
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: libgpgme-dev : Depends: libgpgme11 (= 1.10.0-1ubuntu1) but 1.10.0-1ubuntu2 is to be installed E: Unable to correct problems, you have held broken packages.
I have the dependency libgpgme11 installed, but the version is 1.10.0-1ubuntu2, whereas my desired package requires 1.10.0-1ubuntu1.
$ dpkg --list | grep libgpgme11
ii  libgpgme11:amd64  1.10.0-1ubuntu2  amd64  GPGME - GnuPG Made Easy (library)
How can I install libgpgme-dev given my current state?
I searched the installed reverse dependencies of libgpgme11, and this is what I find.
$ apt-cache rdepends --installed libgpgme11
libgpgme11
Reverse Depends:
  libgpgmepp6
  fwupd
  seahorse
  libvolume-key1
  libgpgmepp6
  fwupd
  libgmime-3.0-0
Here are the outputs of apt-cache policy for the relevant packages.
$ apt-cache policy libgpgme11 libgpgme-dev
libgpgme11:
  Installed: 1.10.0-1ubuntu2
  Candidate: 1.10.0-1ubuntu2
  Version table:
 *** 1.10.0-1ubuntu2 100
        100 /var/lib/dpkg/status
     1.10.0-1ubuntu1 500
        500 http://us.archive.ubuntu.com/ubuntu bionic/main amd64 Packages
libgpgme-dev:
  Installed: (none)
  Candidate: 1.10.0-1ubuntu1
  Version table:
     1.10.0-1ubuntu1 500
jkr
  • 111
