I recently installed Xubuntu 20.04 in a refurbished machine with 8GB of RAM, I3 CPU and a IDE Hard drive of 250 GB and plugged it into the TV.
I am facing two issues which I think they might be related:
  1. I need to shutdown because if I reboot, then the wifi adapter does never connect to the modem. It simply spins for like 60 seconds and then a pop up message says "I am not connected to the network".
  2. The maximum download speed I get on this machine is 2Mb/s, while my connection at home is 15. I can get 5Mb/s when I use boot into windows instead of Linux. Obviously If I am downloading something or watching youtube any other page I want to open takes centuries to load so I am only able to do one thing at the time.
I see several questions with similar issues but they are for older Ubuntu version and those fixes did nothing for me.
Can someone advice how to overcome this issue in Xubuntu 20.04?
Information:
matias@telee:~$ ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: eno1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN mode DEFAULT group default qlen 1000
    link/ether 80:c1:6e:f4:15:a5 brd ff:ff:ff:ff:ff:ff
    altname enp0s25
3: wlxd03745ebc655: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DORMANT group default qlen 1000
    link/ether d0:37:45:eb:c6:55 brd ff:ff:ff:ff:ff:ff
matias@telee:~$ lsusb Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 006: ID 2357:0109 TP-Link TL WN823N RTL8192EU Bus 001 Device 005: ID 0c45:64ab Microdia Bus 001 Device 004: ID 248a:8367 Maxxter Bus 001 Device 003: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode) Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
matias@telee:~$ lsmod | grep rt rtl8xxxu 135168 0 mac80211 1024000 1 rtl8xxxu cfg80211 888832 2 mac80211,rtl8xxxu btrtl 24576 1 btusb bluetooth 638976 41 btrtl,btintel,btbcm,bnep,btusb,rfcomm parport_pc 45056 0 parport 65536 3 parport_pc,lp,ppdev
I am running Ubuntu 22.10 with a TL-WN821N USB dongle and was lucky to get 2 MB/s. The common element with your issue is the rtl8xxxu driver showed up for me as well.
I noticed other devices on my desk getting normal speeds and I plugged the dongle into a windows machine and it ran faster.
I did more googling and found this, which 100% solved my issue,
https://github.com/Mange/rtl8192eu-linux-driver
After following the instructions and building the new driver I get 50 MB/s.
sudo apt-get install git linux-headers-generic build-essential dkms
git clone https://github.com/Mange/rtl8192eu-linux-driver
cd rtl8192eu-linux-driver
sudo dkms add .
sudo dkms install rtl8192eu/1.0
echo "blacklist rtl8xxxu" | sudo tee /etc/modprobe.d/rtl8xxxu.conf
echo -e "8192eu\n\nloop" | sudo tee /etc/modules
echo "options 8192eu rtw_power_mgnt=0 rtw_enusbss=0" | sudo tee /etc/modprobe.d/8192eu.conf
sudo update-grub; sudo update-initramfs -u
systemctl reboot -i
At that point you run this,
sudo lshw -c network
You should see this, most importantly it is not rtl8xxxu,
driver=rtl8192eu
Here is a similar example,
Ubuntu 22.04.1 LTS(Jammy Jellyfish) Installing Wifi Driver
peter
  • 191
